Pros/Cons of Front Mount Snowblower vs Rear Mount
   / Pros/Cons of Front Mount Snowblower vs Rear Mount #41
I don't understand the single-stage wish. Mine is 2-stage, and I've had no problems. It's plugged twice (this year, blowing slush) because I couldn't keep it full. That, in 3 years of use. First year I blew back the banks on my seasonal road. That made some friends. =) Anyway, that was plow-pack and no problem. I didn't even have chains then.
The absolute beauty of a single stage snow thrower is that it weighs less and the minute it contacts the snow pack its gone with one revolution of the rotor. if its coated with fluid film, inexpensive cooking spray, and or slick sheet it will be thrown double the distance or more and it will not require a large diameter 3,4, 5 or 6 blade fan wherein the single stage types like the Reist units use a two or 4 paddle design in the center of the snow thrower with shallow(short in height) auger ribbon flights welded to the large diameter rotor to throw the material up and out of the chute and away in one revolution as their is only a very small space for the snow to be conveyed in to the center and it cannot be pushed away and forward of the snow thrower as 2 stage units like mine are always doing in both shallow and deep snow pack.
If the manufacturers built their 2 stage snow throwers with solid rotors rather than open augers they would sell many many more of them.
   / Pros/Cons of Front Mount Snowblower vs Rear Mount #42
I purchased a Woodmax SB-60 from a close friend of mine 2 years ago. Two stage unit, smiling when I handed over the doe Ray me, and was cringing in my mind whether or not my JD855 three point arms would be able to pickup such a heavy machine at 695lbs my tractors arm capacity is 751lbs so you can see the challenge. But, other than the fact I need to turn around (that's another project) this blower is amazing, the low rumble pushing into a huge pile chewing it's way through it is exciting. One thing I am changing is the skid feet problem, I consider it a problem as the blower housing is up and over the skids pushing the skids into the earth. I am adding long 16" skids to the side of housings so weight is even and under the sides. Will be trying fluid film or such this next season. Mentioned earlier about system to help looking to the rear, aiding the twisting, either mirrors or camera, not sure which direction to go here. Going to keep searching for good ideas for my application, thank you for all the posts, extremely valuable.
   / Pros/Cons of Front Mount Snowblower vs Rear Mount #43
There are three more items I am implementing, adding heavy rubber pads for impellor. Already bought 12 volt linear actuator for chute deflector, and 12 volt ATV winch to move and turn chute, and one project not brought forth was maybe a cozy cab WITH HEAT. My old neighbor up on end of road since passed (RIP Francis) he had same year tractor and had Curtis Cab from Worster, Ma and he installed heater, or should I say t-shirt warmer, unbelievable, almost too much heat. Just another slug of ideas I'm slowly implementing one by one.
   / Pros/Cons of Front Mount Snowblower vs Rear Mount #44
I just bought a BX23s and I plan to buy a rear mount because it's cheaper and I'm thinking the FEL might be useful to break up the Sierra cement we deal with in N. California. I will be plowing 200' of driveway, at a family vacation cabin, some of it very steep. (Asphalt
halt and concrete). We pay a guy 700 a year to clear 2 parking spots and 80' feet of driveway,(flat rate, no matter how much or how little snow accumulates) some years he has no work, this year we had storms delivering accumulations of well over 6'. (estimate last winters total snowfall was over 23')
Is my logic sound? The backing up part doesnt bother me, will I get better traction backwards? I saw someone say you're not supposed to push with a 3 point, I push the gannon box backward pretty hard with no ill effect (yet). Just wondering what others with more experience think.
   / Pros/Cons of Front Mount Snowblower vs Rear Mount #45
Snow blowers are way, way slower than plows and for that reason I have a plow up front and blower out back.
   / Pros/Cons of Front Mount Snowblower vs Rear Mount #46
I have been using the Kubota rear mount snowblower on my Kubota BX25 for years, and I am very happy with it. Very powerful, much sturdier than the front mount, easier to put on, and much cheaper. Also frees up the FEL which I use a LOT. Make sure you get the bucket expander from BXpanded .com (Harry Clearman) for the FEL, as it doubles the heaped capacity which you will find very useful when moving snow.
   / Pros/Cons of Front Mount Snowblower vs Rear Mount #47
People say that, but I can blow at 4mph or more and never go over the same spot twice. Also never have to push back banks.
For me, I am faster with a blower. Probably by twice....
   / Pros/Cons of Front Mount Snowblower vs Rear Mount #48
I just bought a BX23s and I plan to buy a rear mount because it's cheaper and I'm thinking the FEL might be useful to break up the Sierra cement we deal with in N. California. I will be plowing 200' of driveway, at a family vacation cabin, some of it very steep. (Asphalt and concrete).
The first thing I have to ask is where the mule is going to be parked? If its parked at the top of the access do you plan on using snow shoes if the weather gets cranky??
Your logic is sound but do not expect to dig frozen snow banks out with the front end loader they are not built for that-only loose materials.
Having the Snow Caster on the rear aids in gaining traction simply because its on the ground and on the skids and acts like an anchor going in either direction. Having the rears loaded with liquid ballast aids in increasing the tractive effort as it has more ability to create and maintain adhesion to the ground.
If you have 2 link V bar chains or 2 link grader chains for the rear wheels all the better as a four link cross chain will sit inside the tread of the R4 tires and be of little to no use to you. You should also have snow chain tensioners for each rear wheel. Some of the TBN members have chains on all four wheels of the mules they use for their snow removal.
If you do not have the rears loaded it will just skid around and act like a beached whale and it will really get stuck until you are more familiar with how your mule operates AKA drive it a lot and I mean a lot!! with the loaded tires and snow caster all summer until you can do everything from second nature then put the chains on it.
You need traction and to have adhesion to create tractive effort you need adhesion=you need weight and lots of weight. Are the rears loaded with liquid ballast? You will need good snow and mud chains even with R4 tires as they will not help much on slopes as they will act like slick tires-this is why I said you need 2 link chains=one cross link set for every two side links of snow and mud chain.
If you have the creeper gear on this mule you will love having a snow caster as you will get rid of everything on the first pass and not have any snow banks.
Filling the bucket with sand will aid in keeping all four tires from spinning with chains on the rear tires to some extent.
Three point hitches are ment to be used for pulling ground engaging implements that is what they are designed for as the majority of them are single acting implement lifting mechanisms.
As far as the snow caster is concerned have you decided on anything like a brand or clearing width yet? Just remember that the longer you wait to place and pay for an order the longer it will take to get to your door.
Do not rush out to buy it just yet as you have the dilema of heavy wet snows to deal as a matter of local practice and a rear mount snow caster with rotating impeller drum that bypasses the chute and spout will aid in removing heavy wet snows as it bypasses the chute and spout and eliminates clogging as long as it is used slowly and at the full 540 RPM Rear Power Take Off engine speed.
   / Pros/Cons of Front Mount Snowblower vs Rear Mount #49
I deal with lots of drifts and always find the blower to be faster and more effective also!
   / Pros/Cons of Front Mount Snowblower vs Rear Mount #50
Not me. I have too much road. Blowing is only for blowing back banks.
2004 John Deere 650H LGP Dozer (A59213)
2004 John Deere...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A56438)
Greenworks...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
Millcreek 5ft 3 Point Aerator (A59225)
Millcreek 5ft 3...
JOHN DEERE 348 SQUARE BALER (A58216)
JOHN DEERE 348...
2001 Bobcat 873 Compact Wheel Loader Skid Steer (A56857)
2001 Bobcat 873...
