LD1
Epic Contributor
And I'll ask, what happens if my 18 or 20 gauge lamp cord tries to pull 19 amps and don't pop the 20a breaker?
Since 18 gauge is rated for 7 amps I would think it's the fault of the person that put the wire on the lamp. And the wire will probably get HOT.And I'll ask, what happens if my 18 or 20 gauge lamp cord tries to pull 19 amps and don't pop the 20a breaker?
If your lamp tries to pull 19A, you've got a problem with the lamp and the cord will probably melt.And I'll ask, what happens if my 18 or 20 gauge lamp cord tries to pull 19 amps and don't pop the 20a breaker?
There is no problem using a HEAVIER wire, as long as there is a 15 amp breaker protecting the 15 amp receptacle. I had a kitchen wired last year and we ran some 12 gauge to 15 amp receptacles on 15 amp breakers because we got a great deal on the wire.Glad to see the inspector catching a real problem. I doubt the range cord is rated for 60 amps and as mentioned the outlet isn't. Many people will also wire their homes with 12 gauge wire and install 15 amp receptacles. Don't mind this much as a failed receptacle will likely remain within a box.
Yes, that's what I am getting at. If its okay in the case of about all other things that plug in, why not for the range.
But I don't think anyone has directly answered the question though. That is...just because the range says 40a, does that mean it can only be 40? Is there somewhere in the code that stipulates that?
I agree and understand that 40a breaker would be best. But what is best and what is allowable by code are often different. So I am asking what is allowable.
Sorry LD1 I could have picked a better time of day to answer your questions. And maybe a better explanation.
With your breakers you are protecting the circuit at it's allowable ampacity. So if you have a 15A circuit, you need all the components to complete that circuit. You need a 15A breaker, wire rated at least 15A and a 15A receptacle. If you need a 50A receptacle, you need a 50A breaker, 50A wire minimum and a 50A receptacle. So you're actually protecting the circuit. You can't plug a 50A range into a 60A circuit because the circuit is not protected properly with with the 60A breaker. You don't have a 60A rated receptacle. Table 210.24 of the 2014 NEC lists the circuit sizes and their protection.
With your cell phone charger, yes you've plugged it into a 15A circuit/receptacle protected by a 15A breaker. The circuit is protected properly.
But now let me say this, I don't have people do things because I "want" them to. I do it according to the code. I hear this every day, "I did it the way you wanted it". It has nothing to do with what I want. If I can't show you in black and white, then you don't have to do it. Actually one of my inspectors no longer has a certification to inspect because he kept tossing his "personal opinion" in at his inspections.
Maybe the breaker has to be sized for the lowest amp rated link in the chain. Ie 15 amp outlet 20 amp wire= need for 15 amp breaker.
Sent from my iPhone using TractorByNet
Okay, I'll buy that. I am not in compliance with the NEC via not being in compliance with the MFG directions.
But since the house was built in 1995, and I am either the second or third owner, I doubt this range is original.
Not that it matters at this point, again, this is just information seeking as I am going to change the breaker, but......
As an electrician, when wiring a residential house, how do you know what size range they will be using? or that it wont be different in the future? Same goes for dryer and waterheater? Allthough I think 30A feeding them is pretty standard.
I know that this isnt the only time I have seen 60A breakers for a range. Probably 50% of the houses I looked at are 60A ranges, the rest are 50A
Very well could have been but now there is a 50amp receptacle in the picture which is why it can't have a 60amp breaker!Maybe the original range was a 60 amp hardwired.
Then somewhere along the line the range was replaced with a 50 amp model with a 50 amp cord needing a 50 amp receptacle and the circuit breaker was left unchanged.
