lilranch2001
Super Member
- Joined
- Nov 25, 2009
- Messages
- 9,114
- Tractor
- Bobcat CT 235
That is a framing style I have never seen before
What is it called?
What is it called?
nice framing work.
Is that 3020 hard to start in the winter? My 4020 definitely is when the temps drop into the 20s, which is nothing up there.
What is it called?
How far apart are your studs that make up your walls?
Eddie
May be hard to tell in last picture but it is framed just like a house
For the doors, use ship lapped rough pine.
Cut boards the height needed, enough for the width of both doors.
Lay out enough boards for each door, clamp tight, one door at a time.
Cut boards to go across the top and bottom of the doors, both sides of each door.
Cut boards to go between the top and bottom boards.
Cut some boards for a center cross, an X or just one board, to keep the door square.
I would use a good waterproof adhesive and screw the boards together but nails will work too.
The door is made of just some ship lapped rough cut pine boards, you can use 3/4" or 1".
Very nice looking door Scrambler
