Need help to identify old air compressor pump
/ Need help to identify old air compressor pump #1
Von
Veteran Member, Advertiser
Western New York
Kubota B2710
After 50 years of service my air compressor pump is in need of a rebuild! I guess all that sandblasting and grinding on the Unimog was just too much for the old girl. But there are no makers names or markings. Just a date cast right into it! (10-24-55) I need some help in identifying the pump to see if I can get parts to rebuild it. Right now it blows air out of the intake, so I guess it needs some valve work for one. And I know it needs a seal at the flywheel side. The flywheel is 14" in diameter. If anyone knows what make please, please let me know! /forums/images/graemlins/confused.gif I hate to have to buy a new pump when all I need is a few parts to make this one right again. Thanks for all your help. Von
Here is another photo. Thanks, Von
/ Need help to identify old air compressor pump #3
I don't know what make it is, but is there any way you can lap the valves? The seal shouldn't be a problem, you can measure the I.D. and O.D. and then look one up in a Chicago Rawhide catalog. You might end up needing rings, also, that might be why the seal started leaking. You can size up the rings and find replacements. That leaves the rods and mains, the mains stand a good chance of being ball or roller bearings and the rods might still be babbit with shims. If it isn't knocking the bearings probably don't need looking at, but if you decide to re- ring it make sure and keep track of any shims you might find under the rod caps. Don't mix up the valves, just this last Sunday I went through the valves on an old 10 H.P. three phase Quincy that hadn't worked right for years. Somebody had stuck the valves in the wrong holes and nobody could figure out why it took an hour to pump up. They thought the valves wouldn't interchange between holes, I ran my fingers through the ports and used a screwdriver to figure out which way the valves worked and got it to pumping a 50 PSI rise a minute. /forums/images/graemlins/smile.gif
/ Need help to identify old air compressor pump #4
Sorry I can't ID the make for you. There is a gentleman on another forum that I read who is an avid collector/restorer of old engines and water pumps. If you get desperate for an answer, maybe you can send him an email. His name is Kevin Beitz. He lives in PA. Here is his webpage:
http://www.angelfire.com/pa/hittandmiss/index.html
and his email: kbeitz@pa.net
Check out his webpage. He has some very nice pictures of neat, old equipment.
I don't know the gentlemen but when you asked the question, he came to my mind.
Regards,
Duber
/ Need help to identify old air compressor pump #5
I ran across this site, it sounds like they have parts for just about anything and some of the personnel have been around long enough to be able to help you out.
http://www.iccparts.com/
/ Need help to identify old air compressor pump #6
Hey Von, did you ever get that compressor pump overhauled?
What was it? Mine looks EXACTLY like yours.
I am exactly in the same spot, after years mine only gets to 90 psi instead of 160, so I think somethings gone south in the valves of the high pressure head.
Thanks, Jiggs.
/ Need help to identify old air compressor pump #8
Thanks, Jiggs.
MAYBE an old Kellogg American.
/ Need help to identify old air compressor pump #10
Might be a Damifino brand.....:D
/ Need help to identify old air compressor pump #11
The part numbers cast into various parts return nothing compressor related from google. One cast number that may mean something is 8-12-77; if thats a date that means its really not that old.
One casting mark that might mean something is an stylized HF, where the right vertical bar of the H is the vertical bar of the F. I can't get a decent macro picture of it, when I get macro-mode figured out I'll put that up.
The compressor came to me on a skid with a 3phase motor I'm not going to use. The pump looks like its had recent work, a full grey paint job and the paint still in the vee belt grooves.
Yes, a ten year old thread is old, way longer than my memory on a good day. Thanks all.
/ Need help to identify old air compressor pump #12
Looks somewhat like an early Atlas, but the ones i worked on were larger and had a LOT of reed valves. No help I know, but it helps my old memory to yak about it. As soon as it hits me, someone will have the answer. Haha
/ Need help to identify old air compressor pump #13
Its a Brunner... I guess they went away in the 80's.
Thats a start, now I need to find what model, and then who might have parts....
Onward... Jiggs.
Flex King KM 7 Section V Plow (A63688)
Flex King KM 7...
John Deere XUV825E (A61307)
John Deere XUV825E...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
KBH Tank Trailer (A63688)
KBH Tank Trailer...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
