Converting a woodsplitter into a firewood processor
/ Converting a woodsplitter into a firewood processor #1
Scooby074
Super Member
Nova Scotia
BX 25, ZD 326
Ive begun the process of converting my homebuilt Timberwolf clone splitter into a processor. Sorry for being slack with the pics, I keep forgetting the camera
The build thread for my splitter is here: http://www.tractorbynet.com/forums/build-yourself/219145-woodsplitter-build-timberwolf-clone-7.html
Before:
Im using the Wallenstein WP processor as the basis for my conversion. Instead of the complications of a hydraulic saw, Im using a gas powered chainsaw. There will be a home made hydraulic winch as well
Log cradle. Made from 1.25" and 2" square tubing.
"Custom" bar nuts. M8x1.25 coupler nuts are not available local. So I welded a M8 nut onto a 7/16" standard coupler nut
Mockup of hinge
Closeup of saw mount. Saw will be easily removable, just like the Wallenstein
Ill try to grab some better shots. These were all that was on my phone
/ Converting a woodsplitter into a firewood processor #3
I need the pics!!!!
Mockup of hinge
Infeed ramp and hinges
Figuring out the layout for the winch
If there is still an issue, let me know
/ Converting a woodsplitter into a firewood processor #6
How is your saw mounted on to the machine
/ Converting a woodsplitter into a firewood processor #7
I have been to alot of auctions seeing bits and pieces of firewood processors being sold. One guy worked for the state of Ohio and he even had the harvestor chain, bar, and pump aquired for his build. Several three valve bodies were also sold along with a three ft. x five inch cylinder.The stuff was not in one group but was sold thru out the day. I figured it out to late. Your build looks well thought out and nicely executed.
Thanks.
It would be nice if there was those types of auctions here!!
Made a hole cutter for my torch. To cut out the end plates for the winch spool
Welding the spool
Finished winch
/ Converting a woodsplitter into a firewood processor #11
It's looking good.
/ Converting a woodsplitter into a firewood processor #12
Kick *** processor.. I really could put that to use.. I built a big outdoor boiler/stove and she eats 8-10 cords yr. All I have is a hyd lift to hoist the big stuff.. Not everything gets split but the stuff that does is very time consuming.. Nice work..
Thanks for the compliments.
Its coming along.
Got the winch mounted.
Got to build the feet to prevent the processor from being dragged by the winch and build the ramp for the rounds to roll down into the splitter. Then tackle replumbing the hydrulics to a new location. If I have time I might rework the outfeed tables, but they might have to wait till next season.
Now for a bit of TV cookshow timelapse magic:laughing:. Its about 95% done now.
Looking at the winch
Closeup of the saw mount
Winch cable and motor installed.
Controls. I managed to use most of the existing hoses by being creative:D Hey, hoses are expensive!!!. I needed 3 new 1/2" ones for the winch motor, one 3/4 return line and one 3/4 pressure line from the splitter dcv to the cylinder head . Both 3/4 were less than 3'. Not bad.
Almost done now. Just need to add the log length stop. Some supports for the axles. And a lock for the log lift so it stays in place during towing and when parked.
/ Converting a woodsplitter into a firewood processor #15
It looks good.:thumbsup: At this rate you will be up and running this weekend. I have a few questions. Will need a roller to keep the cable from rubbing up top were the log enters the processor? Will you need a ramp to get the log onto the processor? How do you let the cable out on the winch, do you have a free spool or are you just going to run the cable out?
/ Converting a woodsplitter into a firewood processor #16
Very nice work -- I love it! Can't wait to see a video of it in action.
Right now the cable lightly rubs on the ramp. A roller might be in order. Im not sure yet, its not a big deal, just scraping the paint. There is a log ramp there.
To get the cable out, I just run the winch in reverse. Freespool would be ideal but so far I can just pull off about 20' at the winch and run over to the logs.
Video to come, which might show operation better
The feet are working perfectly. So far the processor is rock solid when winching.
The lock for holding the chainsaw in place. Originally I planned something fancy with a over centre mechanism, but a hitch pin works just as well
Blurry shot, sorry
Close up of the log length stop. Its just a chainsaw whip. Cheap solution, only $4.95:laughing: Adjustable from 0" to 24" length, which is about the maximum my splitter can handle.
Operators station
Saw mounted
A little test run. Its much, much faster and easier than doing it the old way. Tons less handling.
Woodsplitter at the end of the rainbow.. Id rather a pot of gold..lol
/ Converting a woodsplitter into a firewood processor #19
It looks good. You can't tell it was a splitter turned into a processor.
/ Converting a woodsplitter into a firewood processor #20
It looks great! I did a similar thing. I found that the bar didn't seem to get enough oil idling in the vertical position so watch it.
One of my problems is that I don't have the proper space to set up and no equipment to stage the material. If I had a place to leave it set up i would build a wood deck to roll the logs onto the infeed table.
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
New/Unused Hercules ATV Sprayer (A65583)
New/Unused...
2005 MACK CV713 DUMP TRUCK (A65643)
2005 MACK CV713...
(1) 20 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
