Hydrostatic trasnsmission vs. gear drive
/ Hydrostatic trasnsmission vs. gear drive #1
Hermio
Gold Member
Clarksville, OH
Mahindra 5035 HST w/FEL and 4-way bucket; Ford 4110
Many forums have discussed the transmissions available: gear, shuttle or hydrostatic. One point that I have not seen mentioned is safety. With any gear drive tractor, if you get into a situation where the tractor is apt to flip over or roll over, you must rapidly find the clutch and disengage it before the rollover occurs. The whole process may take less than a second, and you have to find the clutch while you are in the process of being tossed about on the seat, or maybe even tossed out if you are not wearing a seatbelt. With a hydrostatic drive, all you have to do is stop pushing down on the HST pedal, and it will stop almost instantly. If you lift or drag heavy loads on slopes or in woods, this can save your life. Unless all you do is flat work with no heavy pulling loads, you should seriously consider an HST model. By the way, the lower theoretical efficiency of an HST drive is often made up for in mowing or similar applications by being able to speed up or slow down as the load changes, whereas with gear drive tractors, one tends to stay in a gear selected to let the tractor do the job in the toughest areas, and then not work as fast or as hard in the easy areas.
/ Hydrostatic trasnsmission vs. gear drive #2
I've been running manual/gear transmissions for nearly 40 years and have no idea what you are talking about.
/ Hydrostatic trasnsmission vs. gear drive #3
As with everything, safety involves knowing your equipment & being proficient in operation. It makes no difference whether it is HST or gear, if the operator doesn't know how to safely operate it, he is not safe. In an impending roll over, a real one-not a "I think I might be in trouble" type, the last thing you would be thinking of is pushing in the clutch OR taking your foot off the HST pedal. When a real rollover occurs, it is so fast that you don't have any time to react to anything. THE ONLY safe thing to do is plan your work and think ahead so you don't get into an emergency situation. Failure to engage the brain before getting on a piece of equipment is what causes 99.99% of accidents. The .01% is mechanical failure.
How much of that has been in the woods? When going into woods that have been logged but have brush grown up, sometimes you cannot see a stump due to the brush, and that is but one of many things that can cause a rollover. Another potential problem is bush hogging a trail one direction, then going back the opposite direction. I did that once and had a downed 2" sapling pop up and get pushed up into the path of my chest. If I had been using a gear drive tractor, the sapling would have run me through. As it was, I just instinctively lifted my foot, which stopped the tractor and merely got severely bruised on my rib cage. (It hurt when I breathed for about a week.). Yes, I have used gear drive tractors in the woods also, but after that kind of incident, I am very leery of them. I prefer to use them only in open spaces where there are no hidden hazards. I am planning to buy a Mahindra 5035 HST when my funds permit. That will replace my similarly-sized Ford 4010, which is on its last legs.
/ Hydrostatic trasnsmission vs. gear drive #5
I guarantee there will be freak accidents where gear/HST will be completely irrelevant, and someone can probably find a scenario where HST would be less safe than gear. To me, this is a bit of a stretch. I certainly don't feel like my geared Deere is less safe than my HST Kubota because of the transmission, same way I don't feel like my manual BMW is less safe than my automatic GMC because of the transmission.
/ Hydrostatic trasnsmission vs. gear drive #6
I've been pushing in clutch pedals for over sixty years. I know what the OP is talking about.
Not really a valid analogy. To stop a car, you must use the brakes whether you have a manual or automatic transmission, so there is no difference in safety. To stop a rollover that might be caused by hitting an unseen object, you just have to stop delivering power to the axle. As a bonus, when you stop pressing the hydrostat pedal, you also get braking action.
In my case, I am alive today because of the hydrostat transmission on my Kubota, as I described previously.
Another aside: a hydrostatic transmission is NOT an automatic transmission. There is nothing automatic about it. It is fully manually controlled. It is just an infinitely variable transmission.
/ Hydrostatic trasnsmission vs. gear drive #8
I have seen some instant pro's do some dumb things on easy to drive HST's but also have seen bad things happen on old geared units. The tractor doesn't do stupid, the operator does. Give the same people that do strange things on a tractor a chainsaw and see what happens.
I, too, have been pushing clutch pedals for more than a few years-45 to be exact. I learned to drive with a manual transmission. So, for me, it is not a matter of skill. Now I will expand on the fuels efficiency angle. If you have a variable terrain you are mowing, with an HST, you will tend to speed up or slow down in response to conditions. With a gear drive tractor, you will tend to keep in whatever gear allows you to operate in the toughest areas without stalling out. That means you could go faster in some areas, but you don't, because you would have to change gears, which means stopping the tractor with a purely manual transmission. Few will do that. Thus, the hydrostat saves time and is more efficient in such cases. It also lets you use a smaller tractor. My Kubota happens to be 16 Hp (about 12 PTO Hp.) Yet I have had no trouble running it with a 60" finishing mower, a 4' bush hog, and a 50" rototiller. The 5 Hp per foot of Bush hog width would suggest I needed 20 PTO Hp for my bush hog, or at least 25 engine Hp. But with the HST, I can slow down easily when needed, and speed up when possible. My Ford 4110 is rated at 54 engine Hp. I run it in 6th gear (out of 8) when using a 6' bush hog. I could run it faster in some places, but it would stall in a higher gear in really heavy grass, or when mowing down small saplings. So, I keep it in 6th gear.
While it is true that most accidents are caused by operator stupidity, what we are talking about here is intrinsic machine safety. I maintain that in the woods, an HST transmission is intrinsically safer than gear drive. That does not mean that accidents will never happen with one. It just decreases the odds.
/ Hydrostatic trasnsmission vs. gear drive #11
Other scenarios:
Not being able to hear a potential danger (a person or object) because either hydro engine rpms must be higher or tranny whine.
Close proximity of hydro fwd/reverse pedals (some models): Increased chance of accidental wrong direction versus manually moving a shifting lever (IMO).
There's many scenarios where there is a safety advantages of being able to quickly apply 1 independent rear break while maintaining power to the other wheel. Something not easily done on (some) hydro models.
Ok, ok I'm playing devils advocate here :devil:, and have an obvious bias. As been said before, there's pluses and minuses to both, and it comes down to personal preference. :2cents:
Other scenarios:
Well, at least I don't have to worry about not hearing trees and stumps! I get you on the noise, though. It is my one complaint about HST drives. But my old Ford is actually louder, due to engine noise. The Mahindra 5035 HST is much quieter. As for engine rpm, that has nothing to do with the HST. Today's tractor engines tend to run at higher rpm because it allows the manufacturer to increase Hp more cheaply than to increase engine displacement. Today's gear drive tractors also have higher rpm than that of the older gear drive tractors. In fact, the Mahindra HST models have exactly the same engine as the gear drive models.
On a somber note, I once did run over a young faun with my Ford while bush hogging very tall grass. I simply did not see it until it was too late. The faun hid there quietly thinking it was safe. It made me feel very ill.
/ Hydrostatic trasnsmission vs. gear drive #13
I have a HST and I sure wish my Dad had a HST. He has a Case 1390 4x4 with Ag tires and that thing will crawl through the hilly woods (no trails) with only a big tree to stop it. At his age, a HST would allow him to do work at a more controlled manor.
/ Hydrostatic trasnsmission vs. gear drive #14
You must think I am stupid, but I was making analogies which seemed to cruise right over your head.
You have made some valid points in this thread, but I think you should stop short of pushing them as fact. Having operated and owned gear and HST tractors, I just don't think anyone with experience should limit themselves to an "opinion". Tractors are dangerous in many ways, and as soon as you think you know something it means you can become complacent. I think HST and gear tractors are equally dangerous, and I think the each have pluses and minuses when it comes to safety.
As for fuel efficiency, HST models lose quite a bit right off the bat, in the conversion of mechanical energy to hydrodynamic energy and back to mechanical. You can compare the PTO horsepower of HST and gear variations of a common model to get a general idea of the power loss, which tends to run in the 5-6% range. Integrated over time, that adds up to a lot, and is a far bigger effect than gear changes/etc. You can spin the 5-6% number a bunch of ways, but the easiest way to think about is that for the same amount of power put to the ground, an HST tractor will have to run at higher RPM and burn more fuel. There is no way around that.
I do think HST is superior for loader work and for the things most compact tractor owners do, which is why my new tractor is HST. But I am not under any illusion about safety, and I am well aware of the power/efficiency loss when there's an HST pump between the engine and the ground. The gear model of my tractor was unquestionably more effective at putting power to the ground.
/ Hydrostatic trasnsmission vs. gear drive #15
As others said safety is mainly due to the operator with a small portion due to mechanical failure.
I am only a hobby operator and have just had three tractors, a 9N, then a gear drive Kubota L275DT and now the DK35 HST. The L275 was a huge improvement over the 9N due to the 4WD and effective brakes. Like the OP, I find the DK35's HST much easier to operate and safer in exacting conditions that the L275 gear.
My work is often on rough hilly trails and close conditions near the house. For example, when reversing with a blade to pull snow away from a building I can go as slowly as I want just by easing up on the HST pedal and stop just by releasing the pedal. The HST acts as a brake. Once I have started forward I can increase to the maximum desired speed with the HST pedal. There are no engine speed or gear changes required.
With the gear tractor I had to change gears, lower the engine speed or slip the clutch while backing to the building. The other concern I always had, but it never happened, was the damage that could be done if my foot slipped off the clutch. If your foot slips off the HST pedal you just stop(at least on moderate slopes). So I think in that situation the HST is more forgiving if someone makes a mistake.
The HST lets me do more exacting work on rough ground where I did not go with the gear tractor. I have never come close to rolling either tractor but am able to do more with the HST because I can more precisely approach touchy spots.
As others said, accidents are over 99% up to the operator. We need to recognize the hazards, know our skill level, and know when to back off. An HST requires less operator skill but nothing will save us from poor judgement.
I think for small acreage owners, hobbyists and others in non-production situations an HST is the better choice.
Another HST advantage over gear for some of us as we age(I'm 71) is, not operating a clutch is much easier on the old back.
/ Hydrostatic trasnsmission vs. gear drive #16
Mildly amusing to see the "veteran" posters with 2000 + posts get their hackles up when someone articulates thoughts and positions they don't agree with. So far I have not seen the OP make any move whatsoever toward personalizing the conversation. Hey "veteran" TBN'ers..... no need to get defensive and personal. Could be an interesting thread to read if you'll keep the egos in check.
Is it not a fact that HST tractors will stop when you release the pedal, whereas gear tractors require you to depress the pedal AND the brake in most cases? I am not dealing in opinion here. I am dealing in physics. I am not saying you can't get hurt on an HST tractor. Far from it. But since it takes an actual output of organized energy to prevent certain kinds of accidents with gear drives, whereas it takes less with HST, the odds of said accident decrease. This is a simple case of the application of the Second Law of Thermodynamics. (Yes, I am an engineer.)
Now, as regards efficiency, no doubt a gear drive tractor is more efficient in terms of power transmission efficiency. But what I am talking about is total system efficiency, including the engine. It is well known that an engine is less efficient when it is not working at its peak power output. In fact, it is still using fuel at idle, when it is connected to no PTO implement and the tractor is stopped, resulting in an efficiency of zero. Now, consider how each system performs under real world conditions, which usually involve variable load. With a gear drive tractor, most people will choose a gear so that the tractor will not stall during the most difficult work, allowing the engine to loaf along most of the time during the easy work. With an HST, the speed can be varied to make sure the engine is working harder most of the time. (Believe me, with only 16 Hp on my Kubota, I use the variable speed a low when operating a 4" brush cutter. By contrast, I do not change gears when cutting brush on my Ford 4110). This way of operating is more efficient when the engine efficiency is taken into account. It is somewhat similar to why variable frequency drives often save energy in industrial applications even though such a drive introduces some inefficiency.
"Mildly amusing to see the "veteran" posters with 2000 + posts get their hackles up when someone articulates thoughts and positions they don't agree with. So far I have not seen the OP make any move whatsoever toward personalizing the conversation. Hey "veteran" TBN'ers..... no need to get defensive and personal. Could be an interesting thread to read if you'll keep the egos in check. "
Indeed. My intent was not to attack anyone who prefers gear drive. It was to bring up an issue that I have not seen discussed before. Maybe it will save someone's life. My own opinion is that it is not much of a safety issue in farming operations in open fields, but I do a lot of work in the woods, and I am absolutely convinced there is a higher degree of safety there using an HST.
/ Hydrostatic trasnsmission vs. gear drive #19
OP, do you drive a manual transmission daily in your car? How often and how much do/have you driven manuals? Makes a huge difference in how you view the ability to quickly stop a stick.;)
/ Hydrostatic trasnsmission vs. gear drive #20
Gear models are great for spreading fertilizer and sprays as you have a constant speed you can dial in.
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2018 Freightliner M2 106 20ft Reefer Box Truck (A60352)
2018 Freightliner...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
