PDF files?
/ PDF files? #1
smstonypoint
Super Member
SC (Upstate) & NC (Piedmont)
NH TN 55, Kubota B2320 & RTV 900, Bad Boy Outlaw ZTR
In recent months I have noticed that Google searches turn up more and more results that are in PDF form. Rather than obtaining the desired info directly, I have to download and then open the file.
Am I alone in noticing this?
If not, why the increased use of PDF files?
Am I wrong in guessing a difference in costs?
Steve
/ PDF files? #2
It's getting very common.
Maybe it's a lower tech or easier job to update a pdf file than to alter web page content. The link to the pdf remains constant and abstracts the information like a programming constant: defined once and referenced by name everywhere else? That's my uneducated guess.
/ PDF files? #3
A .pdf can be a smaller file than a document saved in one of the word formats.
/ PDF files? #4
Pdf files requires no special skills and allow users who feel comfortable using Word to just do a Save As.
/ PDF files? #5
I use 3D pdf files for my customers like a 2D pdf the software to view them is free. If you use Microsoft office to create a document only those with Micro Soft office can open them. My software is ZW3D a design package that is a solid modeling package, some customers do not have a solid modeling capability so a 3D pdf allows them to see and review but not change or use for manufacturing a design. There are 2D packages that do allow you to change a document but the change is easy to find. A pdf is like a photo so changing it from the originators intent is not impossible but more difficult and easy to find. Tomorrow when I get back to a reasonable internet speed I will post a 3D pdf just to better explain.
/ PDF files? #6
i hate pdf files.
and for that reason i learned
-pdf -.pdf
i add above to end of my google searchs.
/ PDF files?
i hate pdf files.
-pdf -.pdf
Ryan,
Interesting. I didn't know that adding -pdf -pdf would exclude pdf files.
When I Google worldwide vs territorial tax systems I get 276,000 results.
When I Google worldwide vs territorial tax systems -pdf I get 1,070,000 results.
When I Google worldwide vs territorial tax systems -pdf -pdf I get 1,060,000 results.
What the heck is going on?
Steve
/ PDF files? #8
Not sure what computer/OS you are using, but I see PDFs natively in my browser (Safari on a Mac). PDFs are commonly used for documents nowadays, so I am not surprised they come up in searches more often. Usually when you see a PDF it's because the content is in a document and it's *not* a web page. Not everything on the internet is in the format of a web page.
/ PDF files? #9
Internet delinquents love PDF files...especially if you open them with adobe reader...
/ PDF files?
Not sure what computer/OS you are using, but I see PDFs natively in my browser (Safari on a Mac). .
I'm using Firefox with Windows XP. (I know it's time to update.:)) It seems to me that pdf files used to open automatically when I clicked on them. Did this change with Firefox versions?
Steve
/ PDF files? #12
Ryan,
Steve
-pdf = exlcudes everything with PDF
-.pdf = files ending with extension .pdf ((its the dot))
some pdf files leak through without doing the double -pdf -.pdf statement.
/ PDF files?
OK. I missed the dot before the second pdf. When I add the dot I get 895,000 hits.
But why do I get more hits when adding -pdf -.pdf than when I omit those terms?
Steve
/ PDF files? #14
I have XP and Firefox and .pdfs open up in a viewer for me. I think it might be a javascript app running it, so if you have js disabled that might be causing it.
/ PDF files? #15
Please elaborate.
Steve
the below is pasted please excuse the format...you can do further research on the subject...FWIW...
Main client applications
The main application used to open PDF files for display is Adobe Reader. Many alternative applications are also able to display PDF files, such as Preview on MacOSX and Foxit Reader on Windows.
Adobe Acrobat is one of the applications which can create and edit PDF documents.
Main security issues
PDF is usually considered as a static and safe format for document exchange, which is a wrong perception.
The PDF format is in fact very complex, and contains several features which may lead to security issues:
Javascript: Adobe Reader (and possibly other readers) contains a Javascript engine similar to the ones used by web browsers, but with a slightly different API to manipulate PDF content dynamically or to control some viewer features. Potentially dangerous features are restricted for obvious security reasons. However, this means that PDF documents are not purely static, and for example some actions may be used to fool a user (popups) or to send e-mails and HTTP requests automatically. Furthermore, experience shows that many recent vulnerabilities have been exploited using Javascript in PDF.
Launch actions: a PDF file may launch any command on the operating system, after user confirmation (popup message). Different command lines may be specified for Windows, Unix and Mac. On Windows only, parameters can be provided for the command. Until Adobe Reader 9.3.2, the CVE-2010-1240 vulnerability made it possible to fool users by modifying the text of the popup message. Since Adobe Reader 9.3.3, a blacklist restricts file formats that can be opened, blocking executable files by default (but a way to bypass it has been found, and finally fixed in v9.3.4).
Embedded files: a PDF file may contain attached files, which can be extracted and opened from the reader. This trick may be used to hide malicious executables in order to bypass some antivirus and content analysis engines. Fortunately, Adobe Reader refuses to open embedded files if their extension is part of a blacklist, such as EXE, BAT, CMD, etc. However, this blacklist is not perfect and formats such as HTML or Python scripts may be embedded in PDF and launched from Adobe Reader.
GoToE actions: a PDF file may be embedded inside another PDF file, and a GoToE action may be used so that Adobe Reader opens the embedded PDF file automatically without notifying the user. This feature may be used to hide a malicious PDF file within a normal PDF file, to fool many antivirus engines.
Embedded Flash applications: a PDF file may contain Flash applications (stored as embedded SWF files), which bring their own security issues, such as ActionScript content and Adobe Flash Player vulnerabilities. Adobe Reader contains its own Flash Player, independent from the one installed in web browsers. For example the CVE-2010-1297 vulnerability was first patched in the Flash Player on the 10 June 2010, whereas the Flash Player shipped with Adobe Reader was only patched on the 29 June 2010.
Encryption: a PDF file may be encrypted with a password. However, if an empty password is used, Adobe Reader will open it directly without asking the user. This trick may be used to fool many antivirus and analysis engines that do not support decryption.
Parser "flexibility": PDF specifications, Adobe Reader and possibly other applications are very flexible about the structure of PDF files. For example, most people think that PDF files have to start with the "%PDF" magic number, whereas the specifications only say this header has to be in the first 1024 bytes. It is therefore possible to insert around 1000 random bytes at the beginning of a PDF file. This trick may be used to bypass too strict antivirus or content analysis engines, because a fake file header (for example JPEG or HTML) can be inserted. Another example is that the catalog at the end of the PDF structure may not point exactly to each object: Adobe Reader is able to reconstruct malformed files even if some content has been inserted within or between PDF objects.
/ PDF files? #16
.pdf files are universally usable - as the reader, or many variants thereof are free. .pdf belongs to Adobe and their free downloadable reader is Adobe Acrobat Reader. If you download and install this reader, it will automatically install itself to your IE or Firefox browsers. Trust me ... you should install this.
Resistance is futile. You will be assimilated.
/ PDF files? #17
I always thought the reason for the proliferation of the Adobe reader Borg collective was that the ubiquitous .pdf file works cross platform, Windows, Mac, Apple Iphone, and Android, and maybe others for all I know. So you have something that works on about everything.
/ PDF files?
I am well acquainted with pdf files and I used Adobe Acrobat back in the day when I made my class notes available to my students on my university's network. Please see post #1.
Steve
/ PDF files? #19
Hey "7 of 9" was a hottie..:laughing:
/ PDF files? #20
Steve
ask google its there search engine!
Miller Millermatic 212 Auto-Set MIG welder (A63118)
Miller Millermatic...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
2014 BMW 28I AWD SUV (A61569)
2014 BMW 28I AWD...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
500BBL WHEELED...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
