Factory headlights?
   / Factory headlights? #11
Added two LED's on front and rear plus a small one on each side. I like to know what's around me on more than just the front side.
   / Factory headlights? #12
Until I moved to the country with a 2.3 acre yard I would have laughed at anyone who mowed at night. Last year when it was 100-106 degrees for several days I mowed at night just so I didn't sweat/bake to death! I had no issues doing it with my stock headlights but of course more light would have helped. Lights are on the long term list of things to add.
I have noticed that my neighbors with larger farms, that do hay, also mow at night. When I asked why, they said it's for the cooler temps and the fact a couple of them work odd shifts. They all have auxiliary lights mounted front and rear.
Perhaps one day they will make a brighter stock replacement bulb, coolerman. Your link pretty much stopped me in my tracks looking for that Holy Grail replacement light!!! I was hoping to cheat, and not add more lights. Maybe I can hold out another year until they make a brighter factory light.
   / Factory headlights? #14
Until I moved to the country with a 2.3 acre yard I would have laughed at anyone who mowed at night. ....................................
Our original lot was 2-1/4 acres and my BIL & I split the land lying between our properties. That added another 1-1/3 acres or so. I prefer to mow in the daylight but it isn't always easy to do that. Weather, schedules, etc have sometimes made it necessary to mow at night. A few years ago I was well into the mowing season before being able to mow in the daylight.
This past winter was a little more the way I like it and there was snow to remove even when the sun wasn't shining here. The extra light was welcome.
   / Factory headlights? #15
Hard to beat the cree LEDS.I have added them to my tractor and Kubota RTV 900.
   / Factory headlights? #16
Yep- the cheap Chinese (I guess about all the LED lights are from there) lights work very well. I had some 18Ws on my old tractor, for night snow removal, and now I have some 27W lights on my newer tractor, mostly for when I have to go out and plow to stay ahead of the falling snow. I highly recommend installing them. They work.
   / Factory headlights? #17
I am seeing a lot of threads here regarding lighting, and lighting options. I would like to have more lighting in the front of the tractor but don't want hassle with wiring another set up front. I would like to utilize the factory lights that exist but with a much cooler/brighter bulb. My lights after looking them up online seems to use 'marker bulbs' for headlights much like those in my riding lawn mower.
Has anyone (upgraded their current headlights to LED)? This seems to be the most viable option because the wiring is already in place and you could squeeze a lot more light from the already installed plastic light housings. Are not LED's a lot cooler too? So that the extra light produced wouldn't fade these new plastic lenses. It just seems like an easy solution without all the hassle. Perhaps someone out there has done this and will chime in.
thanks
don
Since the Kioti I purchased already has projector headlights, I've entertained installing an HID lighting kit at some point. I don't know what tractor you have so I don't know if HID lights are an option or not. That said, the little IP67 and IP68 LED lights out of China are an inexpensive way to throw more light down range. I skipped over retrofitting HID's in my truck and simply installed a 30" light bar. Overkill for a tractor but you see what I mean.
I ordered a set based on another thread found while browsing the web. They only cost 7 bucks each and I thought that was worth the risk, even if they don't shed more light on the subject. They are LED and supposedly put out 800 lumens each compared to the factory lights at 400. I figured that I would get them and do a night test to see if they are worth the 16 bucks total. If they don't pan out, it wasn't that big of a loss. I will post results with night pic's before and after... For those that are curious.
There are going to be No modifications to wiring whatsoever and this should be (plug and play) with lower current draw as a bonus.
   / Factory headlights? #19
I'm looking at getting a single big LED flood light to mount on the front brush guard. I'm waiting on prices right now. This light is a marine waterproof floodlight. 50 watts - 3500 lumen. Its a big light - 12" wide x 8" tall. The dealer is J.A.McDermott out of NY.
And no, it won't melt the snow on my mile long driveway - I'll still have to blade it.
   / Factory headlights? #20
I just wanted to point out that if someone has a tractor that uses an actual headlight bulb, it's possible to swap out HIDs fairly inexpensively (around $60-80 per pair). DO NOT install these into cheap housings made for 1156 or other similar marker bulbs...they can't handle the heat.
LEDs don't draw much current by design, per lumen. But eventually, to get the light output desired they can still put out a lot of heat. So, beware :)
2014 Bolens 11A-020W765 20in Push Mower (A55973)
2014 Bolens...
Informational Lot - Shipping (A56435)
Informational Lot...
Mini Skid-Steer Forks (New/Unused) (A59225)
Mini Skid-Steer...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
JOHN DEERE 650 TRACTOR (A52708)
JOHN DEERE 650...
