Rear blade question
/ Rear blade question #1
Boss302
Ohio
Cub GT2544. John Deere 2025
I have a 2025 and I want to get a new rear blade soon to use mainly for snow removal this winter. I need some input I'm leaning towards the Woods RB60 because it's looks solid,I like the features, and it is made in the USA. My local JD dealer only carries the Frontier brand and I did not ask if it was made in the USA and it seemed a little pricey. Any input would be great thanks.
/ Rear blade question #2
Boss I got the Frontier RB1072 and it was made by Woods and is the Woods RB72 it's just painted green. I even called the Woods company to get parts numbers for the Frontier to order skid shoes for the RB1072. Don't forget if you angle the blade it cuts down on the width your plowing. I've used mine for snow clearing and it worked fine. My biggest issue and many I think would agree that in years with a lot of snow fall you run out of places to push the snow.
Thanks smalltown that's a big help. I might have to go with the tan one :D. I know what you mean about running out of places to put the snow after last winter we had in Ohio. I used my trusty 2500 Cub with a 42' front blade for last 10 years it beats a shovel I wont know how to act this winter with my 2025. Do you have rear ballast when you back blade snow? Dealed filled my rears with washer fluid(at no cost) and wonder if it will be enough weight,I moght have to break down and pay the big $ for wheel weights, about $2 a pound $600 for 4 weights ouch.
/ Rear blade question #4
Thanks smalltown that's a big help. I might have to go with the tan one :D. I know what you mean about running out of places to put the snow after last winter we had in Ohio. I used my trusty 2500 Cub with a 42' front blade for last 10 years it beats a shovel I wont know how to act this winter with my 2025. Do you have rear ballast when you back blade snow? Dealed filled my rears with washer fluid(at no cost) and wonder if it will be enough weight,I moght have to break down and pay the big $ for wheel weights, about 2cents a pound $600 for 4 weights ouch.
So you are adding 30,000lbs of weight to your rear wheels? That's just nuts.:confused2: Not quite sure how you're doing that, but it's still nuts. Enough of this sarcastic :rolleyes: talk.
Maybe try land pride? An RB1572 or even an RB1672. Might want to consider Everything Attachments. They have some nice rear blades at a reasonable cost.
/ Rear blade question #6
Yeah that's correct, woods makes the frontier blade. Expect to pay approx. 25% more for the "green" paint. I do think the paint on the frontier is a little better though. John deere specs must be a little higher? Shop around your john deere dealers. I bought a 6' frontier some years ago for $550 new. Other dealers ranged from $650-$850. Check out a bushhog brand. I bought one last year and it is nicely built.
/ Rear blade question #7
I have the Land Pride RB3596 and it works great. My tractor, with the rear blade & FEL w/bucket, weighs 9350.
I do have Rimguard in my rear tires - it adds 740# per tire. It helps very much for stability and traction. This tractor makes snow plowing my mile long driveway a breeze.
BTW, adding fluid to your rear tires is just about the cheapest way to add weight - even if you have to pay for it. Before you get all excited about adding extra weight - give the plowing a try the way you are setup now. If you do need more traction consider chains.
/ Rear blade question #8
I used an 84" wide blade on my JD 2320 for snow removal at first. Unless you deal with particularly deep and or wet snow, I'd go as wide as possible. Snow is generally not heavy. But than the blade is too large for any meaningful earth work. Just my two cents.
/ Rear blade question #9
A couple of years ago I bought a 7' blade from Tractor Supply mainly to use for snow. I knew it wasn't as heavy duty as some others, but what the heck, I'm only using it for snow, right? Worked fine until I caught it on something solid which bent the blade big time :eek: :eek: Managed to get it somewhat straight, but it's still not "right".
/ Rear blade question #10
Boss302 I was lucky enough to find my Frontier rear blade on the dealer lot that they wanted to move otherwise it would have been a Woods model. I also like the feature of unlocking my blade so it pivots and follows the contour of the ground. I have much better success with backing up while moving the snow, but I always make sure nothing has been left on the ground to catch on. No weights here, but my area is very flat. If your thinking of buying the shoes maybe the dealer could strike a bargain with you when you buy the blade as the shoe prices are quite steep.
/ Rear blade question #11
Thanks MtnView!
To be more specific, I think our ETA 60" 6-Way value scrape blade would be great on your tractor. It has features that many compact blades do not, like offset and quick hitch compatibility(complete with stand).
Shipping is free to a commercial business or freight terminal within 1,000 miles of Newton, NC.
Travis
/ Rear blade question #12
offset blade *yums*
some issues over the years is "wanting to add weight to blade" from gravel driveway / dirt lane on the farm. the ground dries so stinking hard and gets compacted, the blade will begin to skip and hop over the ground. yes a box blade with scraficer teeth down would help break things up. but....
a box blade normally has a place to set some concrete bricks, or a log across the top of it, for added weight, a rear blade on other hand. really no spot to add weight easily.
pending on other attachements, if doing FEL (front end loader work in the dirt) having 3pt hitch rear blade on as counter weight, and also to help smooth out some ruts as you are working throughout the day works out nicely, finding a rear blade that has enough weight in it, to counter balance the FEL work can be nice.
if you maintain / want to create any trails in the woods, or redo ditches on driveway, 3pt rear blade /offset and the different angling can come in handy! you can angle rear blade some with raising and/or lowering the 3pt hitch lift arms. to get some angle (left and right) of the blade to some degree. but it may not be enough alone for ditches. normally 3pt hitch lifting arm adjustments are more than enough to put a crown on a road.
some folks have make shifted "wings" for there rear blades. some wings, are for snow, to simply make the blade wider. and other wings, turn the rear blade into something that more resembles a "box blade" with its sides and without the scraficer teeth.
folks with concrete driveways / paved driveways, have DIY gauge wheels, so the actuall cutting edge of blade stays just above the concrete, other folks have created "skid shoes" basicly a metal bar on each side of the blade and holds the blade up off the concrete / paved driveway. and yet other folks, use something like gauge wheels, but are more like metal adjustable legs. to hold blade up off the surface soom.
and for others, they have turned the rear blade more into a "motor grader" in a sense, and they extend some metal a good distance behind the blade. with some wheel/s at the very end. this helps with smoothing out little hills and dips, over a longer driveway.
folks that use rear blade say in town, were concrete curb sidewalks or more likely to be. double check your angle bolts, that they turn into "sheer bolts" so when ya do hit the curb, the bolt shears / breaks vs bending the blade and/or damaging the 3pt hitch, or the curb itself.
TNT (top and tilt) for 3pt hitch, works out excellent for rear blades, box blades, and various 3pt hitch rakes. to help fine tune and adjust angle of attack for the blade on the go. to get that nice feathering effect without a lot of extra hassle.
other folks take it a step further, place hyd cylinders on all adjustments on the blade.
double check you have your check chains / sway chains or like on tractor. if blade catches something or you go into a turn with blade down, you could bind the 3pt hitch up and bend /break something on the 3pt hitch. 3pt hitchs are awesome at pulling stuff, but simple basic 3pt hitch can not take the abuse of side to side abuse, without the extra chains / bars.
/ Rear blade question #13
offset blade *yums*
Sincerely, nice long post and spot on! That should be post of month.
/ Rear blade question #14
I have a land pride RBT1572, I don't think the make the RBT version anymore, but I've seen them used, you can angle it sideways (down) to get down in a ditch to scrap it out, I find it very useful. Wider is better, as mentioned earler as you angle it, makes it narrower.View attachment 382201
Thanks to all for the great input and ideas.
/ Rear blade question #16
Anyone have pics of a blade with shoes on it? I have an older Woods RB5 that will primarily be a snow blade fir use on asphalt and would be interested in seeing a shoe set up.
Sent from my idrankthekoolaid device c/o TractorByNet
/ Rear blade question #17
Here are mine, blade is a bit bigger , but same principle for the shoes.;)
/ Rear blade question #18
Thanks MVR, that makes mine look like a tonka toy, but gives me the ideas I needed.
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
(5) ROLL OF 9'X150' HOUSE WRAP (A62131)
(5) ROLL OF...
Single Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A61567)
Single Cylinder...
Godwin CD150M Dri-Prime Towable Trash Pump (A61567)
Godwin CD150M...
2007 JLG SKYPOWER 800S BOOM LIFT (A62129)
2007 JLG SKYPOWER...
