Trailer Tires
/ Trailer Tires #61
So I have a question re; size. My fifth has 235/80/R16 and the Costco Greenball Towmaster Radial is 235/85/R16 @ $145 eac. Can I use the 85 series in place of the 80?
You can use them. The only difference is that they are 1 inch taller.
/ Trailer Tires #62
Isn't the 80 or 85 tread width?
Sent from my iPad using TractorByNet
/ Trailer Tires #63
80 or 85 is the aspect ratio. The tread width would be 235mm, and the measurement rim-to-tread is whatever % the aspect ratio is. In the case of 80, would be 188mm.
Sent from my LGL35G using TractorByNet
/ Trailer Tires #64
Yes, 100% correct.
Tires are measured in MM. So let's take a 285/65/18 like I have on my truck.
The 285 is the tread width in MM. The 65 is 65% of that 285 MM for sidewall height. And the 18 is 18" rims.
Chris
/ Trailer Tires #65
Yes, 100% correct.
Chris
Unless of course we're dealing with english units such as a 35 10.50 r16, but I digress...:)
/ Trailer Tires #66
that tiny bit of increased diameter shouldn't be an issue if you replace all four tires at one.
Not sure I'd want to mix the sizes though.
/ Trailer Tires #67
Yes, 100% correct.
Chris
Just to see if I'm getting this right...your 285/65/18 tires would then have a diameter just a hair under 828mm mounted(?).
/ Trailer Tires #69
To convert millimeters to inches, simply divide by 25.4.
2023 BARRETO E30SGB WALK BEHIND STUMP GRINDER (A63276)
2023 BARRETO...
2023 Giddy Up USA 13ft. S/A Enclosed Cargo Trailer. (A64557)
2023 Giddy Up USA...
Dixie Chopper (A64557)
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
JOHN DEERE 7410 TRACTOR (A64278)
JOHN DEERE 7410...
