Trailer Tires
/ Trailer Tires #61
So I have a question re; size. My fifth has 235/80/R16 and the Costco Greenball Towmaster Radial is 235/85/R16 @ $145 eac. Can I use the 85 series in place of the 80?
You can use them. The only difference is that they are 1 inch taller.
/ Trailer Tires #62
Isn't the 80 or 85 tread width?
Sent from my iPad using TractorByNet
/ Trailer Tires #63
80 or 85 is the aspect ratio. The tread width would be 235mm, and the measurement rim-to-tread is whatever % the aspect ratio is. In the case of 80, would be 188mm.
Sent from my LGL35G using TractorByNet
/ Trailer Tires #64
Yes, 100% correct.
Tires are measured in MM. So let's take a 285/65/18 like I have on my truck.
The 285 is the tread width in MM. The 65 is 65% of that 285 MM for sidewall height. And the 18 is 18" rims.
Chris
/ Trailer Tires #65
Yes, 100% correct.
Chris
Unless of course we're dealing with english units such as a 35 10.50 r16, but I digress...:)
/ Trailer Tires #66
that tiny bit of increased diameter shouldn't be an issue if you replace all four tires at one.
Not sure I'd want to mix the sizes though.
/ Trailer Tires #67
Yes, 100% correct.
Chris
Just to see if I'm getting this right...your 285/65/18 tires would then have a diameter just a hair under 828mm mounted(?).
/ Trailer Tires #69
To convert millimeters to inches, simply divide by 25.4.
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2018 KUBOTA SVL95-2S SKID STEER (A65053)
2018 KUBOTA...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
