Trailer Tires
/ Trailer Tires #61
So I have a question re; size. My fifth has 235/80/R16 and the Costco Greenball Towmaster Radial is 235/85/R16 @ $145 eac. Can I use the 85 series in place of the 80?
You can use them. The only difference is that they are 1 inch taller.
/ Trailer Tires #62
Isn't the 80 or 85 tread width?
Sent from my iPad using TractorByNet
/ Trailer Tires #63
80 or 85 is the aspect ratio. The tread width would be 235mm, and the measurement rim-to-tread is whatever % the aspect ratio is. In the case of 80, would be 188mm.
Sent from my LGL35G using TractorByNet
/ Trailer Tires #64
Yes, 100% correct.
Tires are measured in MM. So let's take a 285/65/18 like I have on my truck.
The 285 is the tread width in MM. The 65 is 65% of that 285 MM for sidewall height. And the 18 is 18" rims.
Chris
/ Trailer Tires #65
Yes, 100% correct.
Chris
Unless of course we're dealing with english units such as a 35 10.50 r16, but I digress...:)
/ Trailer Tires #66
that tiny bit of increased diameter shouldn't be an issue if you replace all four tires at one.
Not sure I'd want to mix the sizes though.
/ Trailer Tires #67
Yes, 100% correct.
Chris
Just to see if I'm getting this right...your 285/65/18 tires would then have a diameter just a hair under 828mm mounted(?).
/ Trailer Tires #69
To convert millimeters to inches, simply divide by 25.4.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2018 CATERPILLAR 307E2 EXCAVATOR (A65053)
2018 CATERPILLAR...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A64194)
1987 Polar 307 SS...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A64553)
2016 Kubota SSV75...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
