alternative gas can vents
/ alternative gas can vents #1
mikehaugen
Elite Member
Lee, IL
John Deere 1070
I read the great idea on here about using the tire valve stem as a vent. My diesel cans already have vents, so I just put it in memory. So a couple months ago I tried it on some gas cans... bad idea. The rubber does not like gasoline and it got eaten. They were milton valve stems. So the problem is that I drilled the can for 5/8" and I have found some replacement vents, but I can only get them in 1/2".
Is there some material that I can buy new valve stems in that will resist the gasoline? Anyone have any other ideas now that I have 5/8" holes in both my gas cans? I thought about epoxy-ing the vents onto the can but don't really like that idea either, I will if I have to though.
/ alternative gas can vents #2
Epoxy paste will tolerate gas well, and seal tightly because it doesn't cure by out gassing or drying out. I used it to patch a gas exposed section of carberator manifold and it held longer than my piston rod did :)
If you found something to vent the newfangled gas cans, please post a link, 'cause I would love to put vents in all my cans....
Thanks,
Thomas
/ alternative gas can vents #3
I used a stepped drill bit to make 1/2" holes for vents (provides a clean hole on both sides) but I got carried away on one, RTV worked very well to fix my oops.
Thanks,
Thomas
They have a replacement spout kit at my local rural king that I bought to replace my cracking spouts on my diesel cans and they came with a vent that I was going to put on the gas cans, but they need 1/2" hole. I think the kit is $7.99.
/ alternative gas can vents #7
I use simple corks. Works great for a couple of my cans. I converted a couple with tire valves and they don't let enough air in.
/ alternative gas can vents #8
It's funny this came up, because the gas cans that I had installed valve stems on just had the valve stem fall off this week - and I assumed it was to the rubber not like the gas either.
I was planning on just putting another valve stem in - mine lasted two years of pretty frequent use, and it always had some amount of gas in it. Since I already have the hole, I'm just gonna put another one in and hope for the best.
On some of my other gas cans, instead of using a valve stem I've just used a 3/8" coarse thread eyebolt - the eye gives plenty of grip and it seems to stay seated pretty well.
/ alternative gas can vents #9
Has anyone figured out how to remove any plastic shavings from the drilling the holes for the vent?
/ alternative gas can vents #10
snip>I read the great idea on here about using the tire valve stem as a vent. My diesel cans already have vents, so I just put it in memory. So a couple months ago I tried it on some gas cans... bad idea. The rubber does not like gasoline and it got eaten.<snip
Don't feel lonesome about the incomplete or mis-information on the valve stems. I got ambitious and put them in 4 fuel cans only to see them fall off after a few months. At least I was fortunate enough to have used 1/2" stems, so I was able to use the now-popular vent caps being sold on eBay, saving about $100 in lost fuel cans.
No - I don't blame the poster that placed the info on the valve stems for my stupidity. I hold myself responsible for not investigating his info. But it did remind me of the old saying "All that glitters is not gold."
I do hope you find a remedy to save your two cans...
/ alternative gas can vents #11
I too had rubber valve stems fail on gas cans. I went to a chrome metal valve stem and left the rubber gasket off of the inside and replaced the outside gasket with a teflon O ring, have been doing fine now for ~ 2 years.
This sounds like a good idea, but I wasn't sure about the size, the ones I have seen in the stores don't specify a hole size. Were yours 5/8"?
I agree, the original post was talking about diesel. I was stupid for assuming it would work for gasoline. No fault of anyone else's.
/ alternative gas can vents #14
Get a metal valve stem at a tire store.
/ alternative gas can vents #15
Here's another possibility I've been considering -
This Male Pipe (NPTF) x SAE 37° Flare (JIC) Bulkhead
plus this
SAE 37° Flare (JIC) Female Cap
3/8" JIC is 9/16" OD, and the bulkhead with 1/4 NPT is about a buck cheaper than the 3/8 x 3/8.
Couple of neoprene washers between the flange and nut should take up the other 1/16" of slop - also, I'll probably cut off the NPT end and just leave the flange. Should let in more air than the tire valve... Steve
/ alternative gas can vents #16
I believe mine were 1/2", but the metal valve stem has a pretty big shoulder, it may cover up a 5/8" hole.
2015 FREIGHTLINER MID ROOF SLEEPER TRUCK TRACTOR (A59910)
2015 FREIGHTLINER...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2024 John Deere 4066R Tractor (A63116)
2024 John Deere...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2021 WACKER NEUSON LIGHT TOWER (A63569)
2021 WACKER NEUSON...
