alternative gas can vents
   / alternative gas can vents #11
I too had rubber valve stems fail on gas cans. I went to a chrome metal valve stem and left the rubber gasket off of the inside and replaced the outside gasket with a teflon O ring, have been doing fine now for ~ 2 years.
This sounds like a good idea, but I wasn't sure about the size, the ones I have seen in the stores don't specify a hole size. Were yours 5/8"?
No - I don't blame the poster that placed the info on the valve stems for my stupidity. I hold myself responsible for not investigating his info. But it did remind me of the old saying "All that glitters is not gold."
I do hope you find a remedy to save your two cans...
I agree, the original post was talking about diesel. I was stupid for assuming it would work for gasoline. No fault of anyone else's.
   / alternative gas can vents #14
Get a metal valve stem at a tire store.
   / alternative gas can vents #15
Here's another possibility I've been considering -
This Male Pipe (NPTF) x SAE 37° Flare (JIC) Bulkhead
plus this
SAE 37° Flare (JIC) Female Cap
3/8" JIC is 9/16" OD, and the bulkhead with 1/4 NPT is about a buck cheaper than the 3/8 x 3/8.
Couple of neoprene washers between the flange and nut should take up the other 1/16" of slop - also, I'll probably cut off the NPT end and just leave the flange. Should let in more air than the tire valve... Steve
   / alternative gas can vents #16
I believe mine were 1/2", but the metal valve stem has a pretty big shoulder, it may cover up a 5/8" hole.
2007 Ford Five Hundred SEL Sedan (A55853)
2007 Ford Five...
(5) 14" X 26# X 171" I BEAM (A57192)
(5) 14" X 26# X...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
UNUSED RAYTREE RMDM70 70" HYD DISC MULCHER (A57193)
UNUSED RAYTREE...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2016 Ford F-150...
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
