Loader Rock Removal
/ Rock Removal #1
NYBOB
Maine NY(Binghamton area)
2007 JD 3720
I am trying to move this large rock to use in landscaping around my house. I have a JD 3720 and I put my pallet forks on to try and pick it up. I got them under the rock easily but my loader could not pick it up. I had my ballast box on the back loaded with concrete, my tires have weights on them and are loaded inside. Could not budge it....
My question is, if I can chain it, could my 3 point hitch pick it up?
Any help would be appreciated.
Thanks
Bob
/ Rock Removal #2
That depends on the size of the rock!! This rock AKA my tombstone stood a large backhoe FEL on it's nose.
/ Rock Removal #3
You hitch will probably lift 50%+ more than the loader, but the rock may still be too large.
Bruce
/ Rock Removal #4
Bruce
Depends on which machine and loader I suppose. My 553 loader will lift 4000 and the 3PH is rated at 3198 lbs. I often find I can use the tractors loader and weight/ traction to pry a good sized rock up out of it's hole but then can't lift it clear of the ground. I end up getting the bucket under it and sliding them over to the edge of the field and into the woods. Sometimes right to the property line.
/ Rock Removal
I am trying to move this large rock to use in landscaping around my house. I have a JD 3720 and I put my pallet forks on to try and pick it up. I got them under the rock easily but my loader could not pick it up. I had my ballast box on the back loaded with concrete, my tires have weights on them and are loaded inside. Could not budge it.... My question is, if I can chain it, could my 3 point hitch pick it up? Any help would be appreciated. Thanks Bob
Forgot to attach the photo
/ Rock Removal #6
I'm curious what you could pick up & move weighing 4000#s that is attached at the pins on loader boom with a tractor weighing just over 5000#s? Move that load 2+ ft out in front of the pins and watch your tractors rear wheels clear the ground attempting to raise 2 TONS with the FEL.
/ Rock Removal #7
I agree. We have the same tractor/loader, and while it is a stout loader it will not pick up anywhere near 4000lbs. I regular unload bundles of 5-6" treated fence posts that weigh about 2500-2700lbs and that is the limit for the 553 loader. With that much weight it won't lift more than half height and it has very little curl power. Not to mention, even with wheel weights, fluid in the tires and a 1000lb+ implement on the back it is hard to keep the rear end on the ground.
Now, maybe he is talking about just the breakout force, ie lifting the edge of a 4000lb rock a few inches off the ground. No way the 553 loader can actually 'lift' that much.
/ Rock Removal #11
back hoe or excavator.
Thanks
Bob
/ Rock Removal #12
You ain't getting my John Deere hat even if you win a bet, and no I'm not going to dig that rock up off the pile it rests on and truck it to a scale to settle it.
/ Rock Removal #13
/ Rock Removal #14
When my tractor can't lift something with the bucket, I drag it using a car hood. I went to the junk yard and got a car hood. I put the smooth side on the ground and roll whatever I have to move onto it and then drag it where I need it. If my tractor can roll it on top of the hood, it can drag it.
/ Rock Removal #15
This might be an out-there idea, but is it possible that you could break the rock in half? Judging from the picture, it appears to be limestone (could be mistaken). This rock could be relatively soft and therefore breakable. I remember as a child camping next to Lake Superior that some people would find granite stones lying around, heat them up in a bonfire and then, using a plank of wood, throwing the rock into the water where the sudden temperature change would shatter the stone. Like I said, this is only one idea
SI2305
/ Rock Removal #16
You might could chain it up and lift it with your 3pt (a boom helps) but don't be surprised if it lifts the front end of your tractor off the ground.
/ Rock Removal #17
[h=1]Caterpillar CAT 992K plays with a Big Stone[/h]https://www.youtube.com/watch?v=1oYmxrnzzNs
Now THAT rock must weigh somewhere near 4,000 lbs. He must have done some damage dropping the back end like he did.
This past week I barely picked up a 15-foot, 8-inch diameter Dogwood tree and root ball from its temporary hole in the ground and transplanted it to a new spot. I was glad I had my 425 lb. chipper hanging off the back of my 2720 and I had to dig a gradual ramp and play with the tree for a bit before I finally wrestled it from the ground. This is why anyone considering a first-time tractor purchase should definitely consider the kind of work they plan to do with it before they choose a size. It's always better to have too much power behind the controls and a little extra weight built in than to be short on either one.
/ Rock Removal #18
I've been told rock weighs more than one thinks by looking at it.
What would you estimate the dimensions of the boulder in the video to be?
Take those dimensions to the site below.
Check out this site:
Boulder Sizing and Weight Estimation
Now, check out this site (Loader specs):
Cat | 992K Wheel Loader | Caterpillar
How much do you think the boulder in the video weighs now?
/ Rock Removal #19
Try picking up just half the stone, move it a little ..
If you can, slide a roller under it. There are no rocks smarter than a man....
/ Rock Removal #20
Not knowing the exact bucket size on the loader it's just a guess but say 6' X8' X 9'X 62.4 x2.8 = 75,000 or there abouts.
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
Sundowner Rancher Express 20FT Livestock Trailer (A63118)
Sundowner Rancher...
2021 Aluminum Carry-On Trailer Trailer, VIN # 4YMBU1015MG131799 (A61165)
2021 Aluminum...
CATERPILLAR 140 AWD MOTORGRADER (A63276)
CATERPILLAR 140...
UNUSED WOLVERINE MCB-11-48W 48" HYD MINI 4N1 BKT (A62131)
UNUSED WOLVERINE...
