Issues with leaving hydraulic and engine block heaters plugged in during the winter?
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #11
Just use a simple timer IF you use your rig at the same time every day. If it’s an emergency vehicle, you have to stay plugged-in. If it’s for snow removal, just use a timer you can set a few hours before snow hits.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #12
I accidentally left my GC plugged in for more than four hours once and found that the temperature gauge was still lower than when the tractor was fully warmed up when I turned the key. I now make a habit of putting the key in my pocket when plugging in. I just recently got proper power in my shop and plan to use a bluetooth outlet if I can find a good one.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #13
I use a wireless remote plug, I think it is supposed to be for Christmas lights and turn it on a couple hours before I have to start it. I've got a small LED marker light I can see from the house when it's on. I had a small blue strobe marker light I got off a wrecked vehicle compliance truck when I was working, to remind me it was on. The neighbours thought there was something wrong as it lit up the lean to that it's under so I replaced it with an solid amber marker light.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #14
Fire trucks typically don't have a block heater wired into the shoreline. It powers a converter that keeps the batteries charged for the truck and any equipment wired to it, such as flashlights and medical equipment. Many departments are switching over to battery powered rescue equipment instead of hydraulic or gas, so there is a considerable power need for the battery chargers. When disconnected, it switches over to the truck batteries for power. It may also power a small compressor to maintain air pressure, so you don't have to wait for it to build up before responding.
How sure are you about that? I have a fire suppression pump for my business and we are required by code to keep the heater on 24/7/365 and can never have it off. It's actually a John Deere diesel motor made for the system. We even need to keep the room it is in heated separately. It always needs to fire up strong and hot ready to go.
The batteries have a completely separate maintainer system than the heater.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #15
I have been in the fire service and EMS since 1977, 22 years as a paid firefighter/paramedic, the rest as a volunteer. Been in many a fire truck and did the specs on several. The shoreline went to an auto charge battery charger, usually a Kussmaul brand with auto eject for the plug. None had a plug for a block heater. Same with the ambulances I have worked on, the shoreline didn't go to the block heater. Some of those did have an OEM plug for a block heater near the radiator but it was never used.
Dual System Battery Chargers
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #16
I won't argue against that experience! and my application is a little different as well. The link to those chargers seem to be for power, not heat, which leads me to wonder...
Do those trucks stay inside in a conditioned area? Or are they outside just plugged in next to the station. All our local FD's keep as much truck inside as they can.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #17
I guess it goes to the old saying "That's what you get for thinking". Why would the manufacturer install the product if you couldn't use it? The manuals are about, maybe 30% safety related. Don't you think they would warn you if there was an issue. Your daughter's diesel mechanic friend is correct if you paint with a broad brush, but if he isn't involved with your specific brand of equipment, the best thing is to read the manual. In the old days we used to leave them plugged in from December through March. The elect cost has to be weighed against the cost of not having the equipment ready when you need it. If you can plan your usage, plug it in 24 hrs prior.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #18
I also have never seen fire apparatus that included block heaters powered by a shoreline, the shoreline just ran a battery charger / maintainer. Some problematic vehicles also had an airline connected, but that was only very early in my career.
Our stuff was always stored in heated bays.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #19
East Texas is going to do things a bit different then areas that need a block heater. Fire trucks in this area have engine block heaters but the fire houses them selves are kept above 55F.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #20
Frontline fire equipment was inside a heated bay. Occasionally reserve equipment might be outside. But then you run the risk of a freeze causing small lines to burst or the pump to freeze up. It is impossible to drain all the water out of the pump or lines. Just too many low spots the way they were run. Ambulances were sometimes outside, especially for private service units. With diesel engines and glow plugs they didn't need block heaters.
2010 John Deere 8345RT Tractor (A59814)
2010 John Deere...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
2012 International 4300 Reefer Truck (A56438)
2012 International...
Zero Turn Mower (A59231)
Zero Turn Mower...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
