Issues with leaving hydraulic and engine block heaters plugged in during the winter?
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #31
The condensation thing from leaving the block heater on continuously sounds like a load of bollocks to me. Condensation generally occurs when something is cold and then gets brought into a warm space - think like when you take a can of beer out of the fridge and it immediately gets condensation all over it. If you have a warm can of beer (like the tractor with the block heater on and warmed up) and put it in the fridge, ever seen it get covered in condensation? No? Me neither.
Now it *could* present a problem if you constantly and repeatedly turn the block heater off and on. If you start with an ice cold engine, then the block heater warms it up, you're bound to get some amount of condensation there. Generally that's not an issue as long as you're running the engine after it gets warmed up with the block heater as most people do, because once it's running and comes up to temperature it will evaporate most of that moisture with the heat.
But if you just run the block heater over and over on a timer from ice cold to warm, but don't ever start the engine and get it up to full operating temperature, I could definitely see it gathering some water in the oil over time.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #32
If you can get a wifi signal to where you have you tractor parked, a wifi plug will give you a timer for on or off and remote turn on from your phone. The feature that I use for my 3500 CTD is, set up an automation scene that turns on between a certain time when below a set temperature! That way, if I need to go rescue the DW, the truck is ready to hook up trailer and go without waiting to warm before getting up the road! I've been her "tow truck" for years. Then have a later time period for weekends. Can always turn on from the phone if needed before even getting dressed! Have found that the truck needs about 60 - 90 minutes pending temps. The little 3 cylinder Iskei only needs 45 minutes. Set it up when plowable snow is forecast. JM2C.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #33
My daughter’s boyfriend is a Diesel mechanic for an implement chain and he said that it was ok to leave the my block and hydraulic heater’s plugged in on my JD 4600. I thought you couldn’t do that…. Is it ok to leave them plugged in?
We’ve had some really cold temperatures up here in Minnesota, so I have been going back and forth to plug it in. He said to leave it be. Thoughts?
Thanks!
-Bob
I have my Mahindra Max 25 plugged into an Amazon smart plug. I have Alexa turn it on about an hour before I'm going to plow snow. Live in northern Wisconsin.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #34
I live in area with some of the most expensive electricity in the state of Wisconsin so I prefer to not leave stuff plugged in unnecessarily
Being plugged in for an hour or two ahead of time seems to help my tractor start plenty easy.
   / Issues with leaving hydraulic and engine block heaters plugged in during the winter? #35
If you can plan your usage, plug it in 24 hrs prior.
Supposedly a factory Cummins 6.7 block heater doesn't need more than three hours before the temp peaks.
I have never used mine since it rarely goes below -10 here, and I really don't feel like messing with a cord when leaving between 2 and 5 AM.
John Deere Frontier Quick Attach Pallet Forks (A59814)
John Deere...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
2000 Sterling L9513 Winch Truck (A56438)
2000 Sterling...
2013 KENWORTH T880 HYDRO EXC VACUUM TRUCK (A59823)
2013 KENWORTH T880...
Commercial truck Frame with Axle (A59230)
Commercial truck...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
