Hill Climbing Primer
/ Hill Climbing Primer #281
What youre saying is that the pinion can overide a torque generated by its own action, that is equal and opposite to the direction of its action. Why do you say that?The above statement is yours. I never said anything resembling that.There's two contentions I claim.First. No tire slippage. No powertrain failure along with enough power to keep turning. No movement of the load attached. Power applied to move the tractor forward. The tractor will become light in the front and without any mechanical interference (wheelie bars, hitch rammed in the ground, etc.) will in fact tip over backward.Second is a question CalG and yourself have avoided. With forward movement where is the load on the pinion bearing closest to the pinon gear, Top, Left Side, Right Side, Bottom?? And to save going back and forth half a dozen posts, explain why you chose whichever you choose.Please forgive my crunched paragraph, for some reason my computer won't separate.
You said that by saying the pinion would continue to turn with infinite traction and a resisting load at ground level. Applied at ground level the unmoved resisting load exactly offsets pinion torque while it is holding back the tractor motion. So how can the pinion keep turning?
I did answer your questions ... but not the reasons. The directions are the resultant of forces to drive the ring forward.
/ Hill Climbing Primer #282
ovrszd
As to your question.
Since spyderlk answered, but you made no follow up of intent or explanation, I interrpreted your motives as "entrapment" with guile.
I prefer not to participate.
With that, my response was made in the return comment questioning complementary forces within the transmission and is also fully stated in posts 95 and 100 (by another, but I concur)
At this time, I have come to realize that you have placed sufficient conditions on your position regarding the inevitability of a flip over to reduce a pulling tractor to an over sized self powered winch. A Lewis winch. which when attatched properly exibits the exact same "two lever " resolution of forces that is being offered as a counter to your position.
Perhaps you can see my points.
cheers
/ Hill Climbing Primer #283
Now we're getting somewhere.
Your statement above that I hilighted is the issue. It is definitely possible for the pinion to continue turning because we have one motion unaccounted for. The lifting of the front of the tractor. And that is exactly what would happen. If all elements of this demonstration continue, the tractor will do a wheelie. It has no choice.
You can demonstrate this with any tractor. You can raise the front tires of your tractor off the ground and hold them in the air, lift them higher, lower them back to the ground, all by turning the pinion. I cannot count the number of times I've done just that when trying to move an object that resisted my attempts.
Now if you add another element, such as CalG's suggestion that you weld the axle shafts to the housing, or if you securely anchor the front of the tractor, then all motion stops.
In our discussion CalG and yourself never touched on the fact that the front of the tractor is still free to do whatever the applied torque requires. In this case it would be to lift. Put the tractor in reverse and the opposite thing happens, the front would be forced into the ground.
Keep all this in mind, no traction loss, continuous turning of the pinion, no load movement. The inevitable result is the front of the tractor rises. Doesn't take any graphs, diagrams, charts, formulas or any other solutions to prove that.
/ Hill Climbing Primer #284
ovrszd
cheers
Once again, you completely ignored the question and replied using big words and complex sentences. Kinda like saying I'm "Wrong", just with more finesse and style, in your opinion.
Yes Sir, I see your points clearly. Just as I don't understand your lengthy and complex responses, you don't understand my clear, simple and concise examples.
Since you prefer not to participate, I'll not reference you in any further posts. In return you have no further requirement to comment on any of my future posts.
Cheers
/ Hill Climbing Primer #285
Can God make a rock so heavy he can't lift it?
I've resisted appending to this thread, but I think I see an issue here. If we follow through on this scenario, the front end comes up. As it comes up, the drawbar is going to go down, staying in line with it's original position relative to the front end of the tractor. At some point however, if the tractor is going to go over the top, the drawbar is going to go under the bottom (if we assume it does not bend/break in any way). In order for the drawbar to go under the bottom, it would then be in front of the rear axle (front end straight up, at a right angle to the ground) because it started below the axle (add 90 degrees rotation from it's original position). And now we arrive at the problem: if the drawbar is now in front of the axle, it had to move forward relative to the starting position. The load didn't move, the tires have infinite traction, so it didn't slide backwards, and torque applied. The drawbar didn't bend, so....as the only component left, we had to stretch the chain/cable/rope by a couple feet to account for the forward movement of the drawbar, even if the rear axle didn't move forward a millimeter.
This is a classic case of the irresistable force meeting the immovable object.
/ Hill Climbing Primer #286
So, lets just say I'm the OP and I'm looking for more than ad hominem, conjecture and the occasional straw man. Would anyone have any suggestion that involved something less than a challenge between Newtonian physics and relativistic physics? Anyone? Anyone?
:stirthepot:
/ Hill Climbing Primer #287
:stirthepot:
Go play on your tractor!;) You need to do more of something that is good for you.:laughing:;);)
/ Hill Climbing Primer #288
:stirthepot:
Hitch to a rigid drawbar below the axle. Pretty safe. Dont jerk. Lengthen the bar to its longest setting for most safety. If the tires dig down be careful climbing out.
... Its mystery vs Newtonian Physics actually.
larry
/ Hill Climbing Primer #290
I concur. The tractor spinning like a wind mill around it's axle center would not happen.
And it appears you concur that in the beginning the front of the tractor will truly rise?
/ Hill Climbing Primer #291
Lets put some numbers to it so we can check whats happening; 1] Diameter of Ring Gear = 1 foot, 2] Diameter of Drive Wheels = 4 feet, 3] Torque on Axle = 20,000 ft-lb.
,,,,In order to impart that torque to the axle the ring gear face must be pushed downward by the pinion with a force of 40K#. There is the potential for this force, but since we have not applied a load the tractor just glides forward in lo gear. No force since theres no opposition to movement. ... Now we stop and apply a resistance to tractor motion. We apply this resistance to the end of a rigidly fixed lever extending straight down to the ground from the tractor body directly below the axle. The distance from the end of the lever up to the axle is 2 feet - the wheel radius. The tether runs straight back, horizontal and at ground level.
,,,,Now as the tractor moves incrementally the force and torque builds until 20K ft-lb is being imparted to the ring gear ... and consequently the axle and onward to the wheel. Since the wheel has 2' radius the rearward force it delivers to the ground is 10,000#. The tractor tries to move forward, but the tether resists that force with 10K# pulling back. The lever it acts on is 2 feet long so the 10K# force on it produces a torque reacting into the tractor body of 20,000 ft-lb around the axle. This torque acting at the point of pinion/ring gear drive - 6" from the axle center - puts a downforce on the pinion of 40,000 lb.
,,,,,,,,,,,,,,ANY other set of numbers would produce the same balanced result. Its the way it works.
larry
/ Hill Climbing Primer #292
larry
Sounds good but what allows the pinion gear to exert force?
/ Hill Climbing Primer #293
There has to be drive power on one side and a force resisting motion on the other .Force relies on there being a counterforce.
/ Hill Climbing Primer #294
So what happens when the drive power is greater than the resisting force?
/ Hill Climbing Primer #295
If the power links to the ground the load moves. The force applied is only as much as needed to overcome the resistance.
/ Hill Climbing Primer #296
Fixed rpm, gear drive and the pinion turns at a constant speed. So what happens if the forward movement is not as fast as the pinion is delivering? Tires may slip, they may not? What if they don't?
/ Hill Climbing Primer #297
,,,,Now as the tractor moves incrementally the force and torque builds until 20K ft-lb is being imparted to the ring gear ... and consequently the axle and onward to the wheel. Since the wheel has 2' radius the rearward force it delivers to the ground is 10,000#. The tractor tries to move forward, but the tether resists that force with 10K# pulling back. The lever it acts on is 2 feet long so the 10K# force on it produces a torque reacting into the tractor body of 20,000 ft-lb forward tip around the axle. This torque acting at the point of pinion/ring gear drive - 6" from the axle center - puts a downforce on the pinion of 40,000 lb.
larry
IF hooked at ground level [or below] AND the tires didnt slip, the pinion would stop OR twist off the axle. The tractor would not tip back at all.
,,,,,,,,,,,,,, I want to add: It is very important that no one try the exact scenario described in the numerical example above. With the pull point extending straight down from axle center the balancing forward torque is exact but the situation is critical and un damped. In the unlikely case that traction and drive forces are real life huge, a NON steady state pull - from quick acceleration like popping clutch - could start a backtip thereby tipping the pull lever forward; in effect raising it. Now the pullpoint is above ground and there is net backtip. ... I set the example up with the lever at the axle position for clarity. For safety that same lever should be located a few inches behind the axle so it would descend if any backtip occured.
larry
/ Hill Climbing Primer #298
larry
Me thinks with you're levers at equilibrium and a torque applied at the pinion that is equal or greater than the tractor center mass to centreline of rear axle the front will continue to rise. You got a few more lever's there in the dynamics of things that don't diss appear in some gear case housing!:thumbsup:
/ Hill Climbing Primer #299
,,,,,,,,,,,,,, No.
1988 Kenworth W900 Day Cab (A62613)
1988 Kenworth W900...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2016 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
