SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,579
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
... or the axle meets the road so to speak. Axle welded to chassis allows no external interaction. Thats different than freezing the tire in place by external means..SPYDERLK Did you miss the detail that the brakes were firmly applied? or the axle shaft welded to the housing?
In this exchange, the tires could be cast in concrete and there will be no different result.
The example is to demonstrate that forces seen within the tractor unit do not manifest external weight shifting unti "the rubber meets the road".
larry
