Hill Climbing Primer
/ Hill Climbing Primer #21
I'd suggest chains on the rear tires and as much weight as you can get in the loader's bucket. Personally, I would not depend on the differential lock...once traction is lost on one tire, a differential lock isn't going to guarantee adequate traction on the other tire...both might spin. Then low gear, seat belt on and going up slow and steady.
Now, if I'm looking at those pictures right...it doesn't look like a steady slope...seems to be a bit of a rise, then pretty steep at the end...is then correct? If so, I use the tractor to drag the logs to the beginning of the steeper section, then winch them up the steep part from above.
To me, the worst scenario would be getting halfway up that steep section and getting stuck (log digging in, for example) Logging winches lift the end(s) of the log up a few inches to prevent this. Your 3PH might be able to lift the end, but that will raise your C of G...so, again, front ballast is essential.
Your 1700 weighs about 2300 lbs plus the loader...figure about 3000 lbs total. Any of those logs that look to weigh more then 1000 lbs...might be worth cutting them in half....make it easier to skid them up that slope.
Another suggestion is have someone else there...just in case.
I think you might want to recheck the weight of that walnut butt log. I am thinking a 16 foot black walnut log that is green and has an average diameter of 18" will weigh over 1600 lbs. Closer to 1700 probably. Even dry it will be quite a bit over the 700 you are predicting. I have a log weight calculator that I use. It could be wrong but it is usually right on.
Just thought you should check again.
:forehead slap: You are right! How could I forget pi, I like pi! I thought there was something wrong, but by repeating my mistake enough times I convinced myself it was right :/forehead slap: Looks like the bigger trees are going to be a challenge. Max draw bar pull is rated @ 2,800 lbs., so the tractor should still be up to the task under good to ideal conditions.
re: taking the hill grade down with the tractor & box blade, How do / did you compact it enough that erosion didn't become a problem. That's why I was thinking dozer.
/ Hill Climbing Primer #23
Dont forget a log arch can solve this problem. Now that we know you probably can't lift the logs in the FEL.. You can use your snatch block idea but using a log arch your logs wont drag in the dirt, with wheels on both ends. I would probably try to make one first.
/ Hill Climbing Primer #24
Just remember with a locked differential and both wheels spinning the back may go sideways.
Now, if I'm looking at those pictures right...it doesn't look like a steadt slope...seems to be a bit of a rise, then pretty steep at the end...is then correct? If so, I use the tractor to drag the logs to the beginning of the steeper section, then winch them up the steep part from above.
Good eye, you're absolutely right. Thanks for the tip. Would using longer rigging, so the tractor is on the flat at the top of the hill by the time the logs hit the steep section, work the same? There's lots of room to run at the top. I also was thinking this set-up would give greater leeway in backing down if traction became a issue. The black walnut will be the only ones I can't cut down and will have to drag as they're saw logs. The ash is just going to be firewood so i can cut them to short lengths to reduce weight.
Well isn't that just the Cat's meow! I'm embarrassed to say I'd never heard of this before. I inventoried (50) trees today, all 16" DBH or larger. A Log Arch just moved to the top of the list of must haves. Thanks!
/ Hill Climbing Primer #27
The black walnut will be the only ones I can't cut down and will have to drag as they're saw logs. .
I am not familiar with your local log market but I think ours is pretty typical. Here a hardwood sawlog is 8', 10', 12' ...etc. plus trim. If it is really high quality a 6 footer may be OK. Are you sure they need to be 16'. That sounds odd to me for hardwood. Or is there a special reason you want them 16 footers ? Just wondering.
From my experience you will have your hands full handling a 1700 lb log even on flat ground. A 1700 lb wagon on the draw bar is very different from a 1700 lb log flat on the ground.
/ Hill Climbing Primer #28
Something I've never been able to figure out is, if you pull the log from the three-point, in order to get it off the ground, how do you keep from pulling from a point above the rear axle?
/ Hill Climbing Primer #29
Look at where your 3pt lift arms are attached to the tractor. They will be attached below the axle center point of rotation. So even if the lift arms are raised to pick up a weight the tractor sees the weight it must pull at this low, below axle, attachment point. This is if you have no top link and you are pulling strictly from the 3pt lift arms with maybe a cross drawbar like this
Using the lift arms to pull gives a pulling point below the axle but there is also a rotational force from the weight of the log using the lift arms as levers which will lighten the tractor front end. This is also true when using the drawbar if there is any tongue weight. There is not much difference between using the draw bar or just the lift arms to pull. Both pull from below the axle. Both can be dangerous and warrant caution. If you catch the log on a stump. root, or rock and stop the tractor the tires will try to keep turning lifting the front end. This is what makes the tractor pulling hard with an already lightened front end go over backwards so quick. It is the drive to the tires not the load that flips the tractor. Don't assume you are safe because you are using the draw bar. Getting the log off the ground by lifting it with the lift arms requires less pull because it doesn't dig in and you are less likely to catch on something so I think it is better.
If you use a setup that also has a top link connection it gets more complicated. If you are interested look up Harry Ferguson the 3pt hitch inventer to see how his ingenious invention works.
/ Hill Climbing Primer #30
Make a sled out of an old pallet(put runners on the bottom) or a car hood. Put the near end on the device and use the longest rigging you can without being cumbersome. You should take most of the danger out of the operation. Big logs with weight hanging off both sides of the tractor while navigating hills is too dangerous. Loss of traction and weight transfer could put you in a difficult situation in a nanosecond. Pull with the drawbar on the belly of the tractor. You could also chain the tractor at the top and winch them up the hills, but this will require purchase of a $300 winch.
/ Hill Climbing Primer #31
This is also true when using the drawbar if there is any tongue weight. >>There is not much difference between using the draw bar or just the lift arms to pull. Both pull from below the axle.<< Both can be dangerous and warrant caution. If you catch the log on a stump. root, or rock and stop the tractor the tires will try to keep turning lifting the front end. This is what makes the tractor pulling hard with an already lightened front end go over backwards so quick. It is the drive to the tires not the load that flips the tractor. Don't assume you are safe because you are using the draw bar. Getting the log off the ground by lifting it with the lift arms requires less pull because it doesn't dig in and you are less likely to catch on something so I think it is better.
NO! The pull point is from the liftarm endballs. Look at the rigid triangle formed by the tractor chassis, rocker shaft, and lift arms tied by the lift links,. It would not be a matter if you had the arms low, but they would have to be chained downward to prevent them floating up if a backtip started.
larry
/ Hill Climbing Primer #32
That's what I think too. If the end-balls are higher than the axle, I believe the effective pull-point will be above the axle and the tractor will want to roll over. This is doubly true if the lift arms are not chained down, and are free to rise up.
It always seemed to me that the safest way to skid a log would be to chain the log to the drawbar with a short chain and then lift the log off the ground separately with the lift arms. That way if the log got hung up, the drawbar chain would take up slack first and prevent any pull on the lift arms. But nobody does it this way, as far as I can tell.
/ Hill Climbing Primer #33
Hmmm. My previous tractor that I had for 25 years was exactly what you have. I can tell you from experience - the easiest and SAFEST way to get those logs to the top of the hill is to put one in the bucket and chain 2-3 together and drag them up the hill with a chain or cable attached to the drawbar. DO NOT use the 3-point to pull a load up the hill. Use nothing higher than the drawbar (ex- don't use FEL or 3-point) to pull the load up the hill. The logs could change position(roll) and very quickly you & the tractor could be in a side pull situation and get pulled over and down the hill.
I had a pto winch which allowed me to have 250 feet of 1/4 inch cable. I pulled one log at a time strictly for safety sake. The winch was attached to the 3-point and drawbar. Tight to the drawbar, loose to the 3-point. It pulled on the drawbar and was kept in alignment by the 3-point. It was a Koenig winch.
/ Hill Climbing Primer #34
Growing up in 2wd tractor World, I've lost count of the number of times I've pulled with the 3pt drawbar and front tires in the air.
/ Hill Climbing Primer #35
Yeah. If they are hi they are a problem for backtip, continuing such until the tractor reaches a very hi angle and they become pinned at the top of their travel with balls near the ground ... but rocker shaft/ lift links are having serious issues. -- If lo and not chained they are initially the same as the fixed drawbar because their tractor attachment H is about the same. The killer tho is that, unlike the fixed, the arms can articulate upward at their tractor fastening. During the backtip there is no damping factor at all because the articulation point[and therefore pullpoint] remains at the same H. If the arms could not articulate upward, the balls like the drawbar end would be forced down as a backtip progressed, lowering the pullpoint. This would self limit the tip. You can only get this benefit if you chain them down.
....I like your proposed method of pulling a log. BabyGrand does it like that. Ref thread:
http://www.tractorbynet.com/forums/attachments/177413-how-do-you-hook-your.html#post2022311
/ Hill Climbing Primer #36
I guess there is a misunderstanding in what I said. As far as the horizontal force required to pull the log forward goes the rods from the rock shaft to the lift arms hang vertically and can offer no horizontal force to the upper part of the tractor during a pull. The entire horizontal pulling force is taken at the lift arm attachment points below the axle which is essentially the same pull point when using the draw bar. I did say in addition there is a vertical force, the weight of the log, that acts with the lift arms as levers to lighten or lift the front end thus transfering more weight to the rear and offering better traction. I also said this vertical front end lifting force also comes to play when using the draw bar only if there is tongue weight on the draw bar. So I agree with you there is a difference in the two set ups.
If you catch the log and stop the tractor during a pull the horizontal pull force suddendly increases no matter which set up you have. In both cases the front end will try to come up driven by the tires. Now comes the trade-off: If you are pulling from the lift arms with the log off the ground the front end is, as I said, lighter, so it comes up easier but the pulling is also easyer so you have less power to the tires reducing the risk of lifting the front end even though it is lighter. Even if it does come up as soon as the rear end rotates back and the log hits the ground the vertical weight of the log is removed from the tractor and the front end suddenly is no longer light so you get a chance to recover from the tip up. Now, if you are pulling hard dragging the log from the draw bar and the log stops dead, when you start to go up you have more power to the the tires because of the harder drag and there is no sudden increase in front end weight. So, to me, there is less chance to recover from the potential tip over.
Which is better is a matter of opinion. And there are so many possible senarios you can't argue which is best. I prefer the lift arms. Pulling heavy logs is dangerous. You need to understand your equipment and the risks. Think and observe what is happening during the pull. Go slow keep the log low as practicle.
/ Hill Climbing Primer #38
You are pulling from the H of the ball ends if the hydraulics is holding them above the attachment point of the arms on the tractor for the reason I said earlier. If the ball ends are, instead, lo you are pulling from the arm attach point on the tractor, and since that point will not move downward as the tractor tips the tip does not self damp. The operator has less recovery margin. BabyGrands method has all the advantages you cite as well as the added safety of a drawbar pull.
larry
Good point about the pitfall of a locked diff. Many touched on this issue, it must be legit.
I liked the answer I saw on a sawmill forum, "My client wants 16' beams, so I need to cut 16' logs", alas that is not my case. I wanted to present the worst case for input. I'll cut them shorter if I need to, but you never know unless you ask. ;)
Another day night & day of rain is giving allowing more time to think this over / read responses. Have to admit, what started as "feeling" there was more to it than throw a chain around the log and drive up the hill has been substantiated by all of your comments. Thanks for all the ideas and warnings. Talking it out is the best way to get the best plan.
/ Hill Climbing Primer #40
I may be misunderstanding your example, in which case I apologize, but I don't think this is correct. If you are pulling from below the axle, then the torque will tend to rotate the front end downwards into the ground. If you are pulling from dead-center on the axle, there will be no torque. And if you are pulling from above the axle, the torque will tend to rotate the front end upwards.
I think what you are saying is that the lift arms attach above the axle, so if you are pulling from the lift arms, there will always be torque to raise the front end--but to me that seems like an argument for pulling from the drawbar, not the lift arms.
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
Adams High Clearance 5 Ton Spreader (A63688)
Adams High...
John Deere 4040 Tractor (A64047)
John Deere 4040...
2014 International WorkStar 7500 T/A Leach 2RIII 25Yd Rear Loader Garbage Truck (A61573)
2014 International...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
