Sightseer 30B
Hi. I am joining as a new member and unfortunately my Kubota experience has started out a bit rocky.
Almost the owner of a new BX1870, but not quite.
I ordered the tractor with 48" mower deck, loader and ballast box.
Dealer delivered the tractor today, but there were a couple of issues.
1) Cruise Control (extra that I requested to be thrown in to complete sale) was not installed.
2) The mower height setting mechanism doesn't appear to be attached to anything. It just floats around.
3) There is a hydraulic leak with a rapid drip from underneath centered near the center of the tractor just forward of the right rear tire.
AND there's more.....
4) I wanted to learn hands-on how to remove and re-install the loader. Both the delivery guy and I had a very difficult time removing the pin on the left side. The right side floated right out, but the left only came out with much pushing and pulling on the loader. Getting the hole lined up and the pin back in took a large screwdriver to attempt to align the holes and then a hammer to drive the pin in. This was performed on a level piece of ground.
After finally getting the loader re-attached, I moved inside my garage to ensure a flat surface. Again, great difficulty getting the pin out and back in.
Obviously, the tractor went back on the flatbed to be taken away. I did notice something key to the problem, I think. With the tractor on a flat surface and the bucket lowered on the ground, the right side of the bucket was about 3/4 inch off the ground while the other corner was flat on the ground. It would appear that the loader was twisted or the tractor was leaning to the left.
Items 1 - 3 should not have happened, but should be easily fixed. But what about the apparent twist in the loader alignment? Is there adjustment the dealer didn't perform correctly?
Tractor was purchased in another state 3 1/2 hours away, so I can't just go make sure it is being fixed correctly. (did save over $2K over local dealer, but perhaps not worth the headache?)
Wayne
Wayne
