Buying Advice Small CUT or large SCUT Advice
/ Small CUT or large SCUT Advice #41
When using my last tractor, I never used the little stop on the position control. I just kept my hand on the 3pt lever and made small adjustments while grading. If I was pulling too much, I'd make small increments up until I wasn't pulling so deep.
I just want to make sure I can make small adjustments. I do NOT want my blade coming out and dumping little humps of rock every time I try to raise it just a touch.
Well then maybe it's better to forego the dual peddles in favor of the position control. Nuff said? ...probably not nuff. :)
/ Small CUT or large SCUT Advice #42
I'm only somewhat familiar with one style of manual position control, so this may not apply, but it sounds like you could get by with one. The type I've seen had an implement control lever that rested in a center position. If you push forward, the implement lowers until you return the lever to center. The farther forward you push, the faster the implement lowers. The opposite is true if you pull backwards to raise the implement.
Since it's an important primary task for you, I'd see if the dealer can set up the machine you're interested in with a blade or land plane for you to try out. That will be the ultimate answer.
That's exactly the way the J2023 is. The 3pt lever is like a aux hydraulic lever. It rests in a center position and will return there when let go of.
I think I may ask the dealer to hook up a box blade and let me try it. That's a good idea.
/ Small CUT or large SCUT Advice #44
I had the "treadle-pedal" on my CK20. Since then I've had the "dual" pedal setup on various tractors. While I prefer the "dual" pedal design, once you're used to either, you'll be fine with it. Some guys here actually prefer the treadle-pedal, while others do not. I'm sure you won't mind it after 10-20 hrs.
I tried one on the older J2030 model. I didn't like the feeling that my right for wasn't flat on the floor like my left foot. It just felt like an awkward position to sit in for any kind of time.
Thanks for the tip. I don't think I would be interested mainly because it's located too far away.
I'm thinking about taking a half day off work tomorrow and going up and testing the 2023 some more.
Well turns out the dealer sold that 2023 that I had looked at. I can't seem to find a single dealer in reasonable driving distance that has one in stock that I could spend more time with.
/ Small CUT or large SCUT Advice #51
Did you find a tractor?
/ Small CUT or large SCUT Advice #53
Congrats! Hopefully it will be a good tractor for you and serve you well for many years.
/ Small CUT or large SCUT Advice #54
Yep, I ordered a new J2023. Should be here in a couple weeks.
Congrats on your New machine and TBN rules apply. Need Pictures please.
/ Small CUT or large SCUT Advice #55
Cool...congrats! I'd love to have a J2023 for some of my chores, but I think the wife might steal it! Pics when you get it, or it never happened :D
Thanks fellas. I'll be posting a lot of photos since there is not much info and photos on the J2023. I'll probably start a new thread in the LS section.
/ Small CUT or large SCUT Advice #58
Hey folks. I'm in a similar position. I'm looking at the LS J2023H and also the LS J2030H. I see where Olympus (sp?) didn't like these tractors not having position control. I've seen the G3033H up close myself, and it has knobs for position control similar to the old way Farmall did the Farmall Cub, Super A, etc.
Is there any reason something like this manual setup couldn't be adapted to the J2023H/J2030H? I thought I had some photos to show what I'm talking about, but not this time.
There's no way to rig any kind of position control for the J Series tractors. The 3pt lever works like an auxiliary hydraulic lever. There is no way to rig a stop that I can conceive. It really wasn't that big of a deal to me. I never used position control on my last tractor.
/ Small CUT or large SCUT Advice #60
Thanks Olympus for the quick answer. I'll try to swing back by this weekend and take better photos of the J2023H in my area if it's still there. Please let me know what you think of your tractor once you get it. I'm definitely leaning towards the LS series, but need to get a few more things sorted out first.
I do remember the ground clearance at the front - just behind the front wheel at being a little over 15 inches tall. That's from a tape measurement I took with me. It could be a bit more or less depending on how you look at it from an angle.
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
211453 (A62131)
211453 (A62131)
UNUSED RAYTREE REDM32-32" EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
2001 Eager Beaver 50 Ton Hydraulic Detach Lowboy Trailer (A64047)
2001 Eager Beaver...
2022 John Deere HPX615E 4x4 Gas Utility Cart (A61567)
2022 John Deere...
BUNDLE OF 10' RE BAR (A62131)
BUNDLE OF 10' RE...
