Welding work today
/ Welding work today
The trailer in question is the black one.
Paid and gone. Yep that's an f150. No, that's not the heaviest thing he hauls.
/ Welding work today #22
Finger nailing is when the coating burns off uneven. Sometimes it's because of bad rods. I made a scarifier out of a heavy 12" H beam. I beveled the beam (like a cutting edge) and then welded backhoe teeth shanks on. I welded all around the shanks with 3/16" 7018. To weld the back of the adapters inside the H beam was a little tricky. I had to bend the rod to fit between the 2 flanges and then had to have the rod almost vertical down because the web was in the way at the back. I struck an arc and then transferred the arc to the shank and kind of let gravity pull the weld down to the beam. It was a blind weld as I couldn't see the puddle. Experience gave me a good idea on how the weld was progressing. It's hard to explain it but you basically get the flux to burn off on an angle. If you just had the arc on the beam, you wouldn't get much weld on the shank. It's easy enough to practice this type of weld though. Put a small piece of plate on top of another plate and see if you can get a nice fillet weld with the rod almost vertical.
Thank you ArcWeld.
See what I mean about walking puddle over to bucket. The quarters were tight and the blind beads were not the best looking. So...
There better not have been any undercut! ;)
Next victim... Patch it up and back to thicket. Overhaul later after he does all the damage.
This guy has been a good customer over the past few years. He is rough on his stuff but believes in servicing.
/ Welding work today #25
Had to use an old truck mirror to see the back of a 2" heat pipe one time to see the puddle, that took a bit of getting used to?:laughing:
/ Welding work today #26
Thank you ArcWeld.
Looks like he needs a railroad track for a bumper on the back of that hog to keep from caving in the frame. I though I was rough on stuff, but this guy has me beat all to heck.
I take it you run a welding shop, so guys like that are your bread and butter I suppose.
/ Welding work today #27
I had to do that in school. We had to place the pipe 6-inches from the wall, and 6-inches from the ceiling, place a mirror on the back side, and Tig weld the pipe.
All the Navy shipyard weldors here do that all the time! :eek:
Looks like he needs a railroad track for a bumper on the back of that hog to keep from caving in the frame. I though I was rough on stuff, but this guy has me beat all to heck. I take it you run a welding shop, so guys like that are your bread and butter I suppose.
Gary- this guy is easy on his stuff compared to my normal lot!
The guy with the hoe is as tough as I've ever seen. His son and I have a running joke about stuff being "Phil tested". I have a small shop and mobile service. It's nothing fancy, dirt floor.
/ Welding work today #29
Since this is a welding thread and I did not want to start another thread.... I have a question.
I have a grade 5, 5/8"bolt broken off in the frame of my JD 555 track loader. Normally I would try to weld something onto it to get it out but this one is going to be difficult to get to. The broken bolt is in the frame. There is a 3/4" thick plate on top of it so the broken bolt surface is 3/4" down in the hole. Also there is a 3/4" thick triangle gusset about 3" inches from where the head of the bolt should be. This gusset blocks straight on access to the hole. Failing any other plan, my plan was to drill a hole through the gusset and then drill out the broken bolt through that hole.
If there was some way to weld on to the broken bolt; like maybe clamping a 1/2" bolt in my welding rod holder and stabbing it onto the broken bolt. Would that weld the 1/2" bolt to the 5/8"? I would insulate the shaft of the 1/2"n bolt to keep it from arcing to the side of the hole.
Any suggestions would be greatly appreciated.
/ Welding work today #30
No that won't work. You're better off to drill a hole in the gusset, drill a hole in the broken bolt, and use an easy out. If you can put heat around the broken bolt just before using the easy out, that helps a lot!
/ Welding work today #31
I know this isn't what you want to hear, but you will need to remove the 3/4" plate to weld to the broken bolt.
If you must try to weld to it as it is, use a piece of pipe or tube. Put your welding rod through the pipe and weld it from the inside.
Also, how did the bolt fail?
Over torque?
Shear?
Fatigue?
Tension?
/ Welding work today #32
Dirt floor or not, you obviously do good work from your photos and customers keep returning to you. Keep up the good work and photos.
/ Welding work today #33
Thanks, SA and CNC. The bolt broke in shear. There are three bolts in a triangle pattern that connect the under-carriage to the frame. To remove the 3/4" plate would mean removing the entire undercarriage on that side. I have had problems keeping these bolts tight and apparently they got loose enough for there to be some movement which sheared this bolt. The other two were distorted and I have already replaced them with grade 8's and new lockwashers. I plan to Locktite them after I get the broken bolt out.
I had considered the "easy out" but my experience with them is that they break and become "hard outs".:mad:
I have bought a 17/32 cobalt drill bit and a 5/8" plug tap to drill the gusset and drill out the broken bolt and to chase the threads. To take this approach means at least removing several track pads if not the whole track to get access to drill the gusset hole and to drill the bolt.
What about left handed drill bit? The old man I was referring to earlier was good at getting bolts out.
Thanks Gary.
/ Welding work today #35
I have never tried a left handed drill bit but it certainly would be worth trying here, and I fit the "old man" profile.....:eek:
/ Welding work today #36
The left handed drill bits work sometimes, but don't bet the farm it will work on something like you got.
/ Welding work today #37
That's good, means you got a good chance of backing it out.
That explaines how it happend, and you know what to do about it.
Won't hurt to drill it. But I would try to back it out with something not so hard as an 'easy' out. Might try grinding an allen wrench square and sharp, so it will cut like a broach, and hammer it in. Chamfer the hole so it starts on center.
If the hole in that 3/4" plate is a close fit, it should help keep your drill in the right place. You might even use a larger drill that will just fit in the hole to start with. Just enough to make a centered drill point. Then switch to the correct size drill either for the Allen wrench attempt or for taping the hole.
[/QUOTE]
Fire dogs I made 5 years ago. I'm surprised how well they look. These folks use fireplace as sole heat and they keep it rolling.
It's all 1", torch cut. 7018 welds.
Made a fire hydrant wrench today. image-1128884200.jpg Just scrap 1/4" Victor torch No grinding done Pentagons are more difficult to layout than I expected???
/ Welding work today #40
Opps!
Wish I had the picture, but.... no camera....
Welded a 5/8 nut on the end of a piece of 1 inch thick wall square tube, making an "adjuster".
'Thought I would do a better job keeping things in alignment if the male threaded part was deep down the hole. I even put a few rounds of masking tape on the threads to make a sort of "pilot shaft out of the deal.
Wouldn't you know it, I burned the puddle deep enough to weld to the thread on the INSIDE of the tube! ;-O
I had to get out the two foot long pipe wrench to budge things into moving at all.
Then once it broke free, I chucked the square shank in the four jaw and braced the male thread (a tooling bolt, hard as hades) against the carriage. Backed right out! But I was worried.
Slathered the thread with Never Seeze and it ran together just fine. Fortunately, the nut was run all the way up the male thread, and that part will nearly never be called for.
The nice part?. All the welds held just fine! ;-)
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
PALLET OF MISC LUMBER (A63291)
PALLET OF MISC...
