avc8130
Is it ok to use the float detent to lower a raises bucket and stop the lowering by returning the stick to neutral?
ac
ac
I don't. It is your machine, operate it however you see fit after you read the manual.
I did notice it is slower retracting and can hear the hiss from flow restriction internally
'Float' allows your bucket to follow the contours of the land.I don't have a manual.. What's a float lol
Good to know, I've been letting it drop while in float too....I did notice it is slower retracting and can hear the hiss from flow restriction internally
Do you have the valve schematic for your tractor. I suspect that in the "Float" position Ports " A", "B" & Tank are connected. Pressure continues to flow out the power beyond beyond port. While in float The oil being forced out of the base end of the cylinder is directed to the rod end and the excess flow is directed to tank. To prevent cylinder rod end cavitation the spool could be made to provide some increased flow restriction to tank while in the float mode.
my :2cents:
