OK to use Float to lower bucket?
   / OK to use Float to lower bucket? #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
Is it ok to use the float detent to lower a raises bucket and stop the lowering by returning the stick to neutral?
ac
   / OK to use Float to lower bucket? #2
I do it all the time when pushing and scraping snow or other similar dirt work.
   / OK to use Float to lower bucket? #3
I have done it a few thousand times when I had a Kubota. As they would lower slow enough that that the bucket would not bang into the ground. On my Kioti, it falls like a rock, and you need the bucket near the ground before you shove it into float.
   / OK to use Float to lower bucket? #4
In all 3 kubota manual of mine it tell you not to. It tell you to have the loader near the ground.
   / OK to use Float to lower bucket? #5
on my kioti dk45se, I do it all the time, it slowly goes down... I have read the owner manual several time and also the shop manual and nothing is against using the float even if the bucket is 8 foot in the air
   / OK to use Float to lower bucket? #6
Just curious ---- what's the advantage? It's never occurred to me that I would want to do that????
   / OK to use Float to lower bucket? #7
I would not do it with a full load.
I am thinking the reason might be that if you drop a bucket with a full load, and go to neutral just before touching ground, it could cause a very large hyd spike and damage a cyl, hose or valve.
   / OK to use Float to lower bucket? #8
I always lower mine in float if I am going to use it in float. On my JD it drops slow enough there is no real impact.
   / OK to use Float to lower bucket? #9
I don't. It is your machine, operate it however you see fit after you read the manual.
VOLVO QUICK COUPLER MAST W/ 72" FORKS (A52705)
VOLVO QUICK...
2017 Caterpillar D5 K2 LGP (A55218)
2017 Caterpillar...
1006 (A47477)
1006 (A47477)
JOHN DEERE 850K WLT CRAWLER DOZER (A52705)
JOHN DEERE 850K...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
