OK to use Float to lower bucket?
   / OK to use Float to lower bucket? #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
Is it ok to use the float detent to lower a raises bucket and stop the lowering by returning the stick to neutral?
ac
   / OK to use Float to lower bucket? #2
I do it all the time when pushing and scraping snow or other similar dirt work.
   / OK to use Float to lower bucket? #3
I have done it a few thousand times when I had a Kubota. As they would lower slow enough that that the bucket would not bang into the ground. On my Kioti, it falls like a rock, and you need the bucket near the ground before you shove it into float.
   / OK to use Float to lower bucket? #4
In all 3 kubota manual of mine it tell you not to. It tell you to have the loader near the ground.
   / OK to use Float to lower bucket? #5
on my kioti dk45se, I do it all the time, it slowly goes down... I have read the owner manual several time and also the shop manual and nothing is against using the float even if the bucket is 8 foot in the air
   / OK to use Float to lower bucket? #6
Just curious ---- what's the advantage? It's never occurred to me that I would want to do that????
   / OK to use Float to lower bucket? #7
I would not do it with a full load.
I am thinking the reason might be that if you drop a bucket with a full load, and go to neutral just before touching ground, it could cause a very large hyd spike and damage a cyl, hose or valve.
   / OK to use Float to lower bucket? #8
I always lower mine in float if I am going to use it in float. On my JD it drops slow enough there is no real impact.
   / OK to use Float to lower bucket? #9
I don't. It is your machine, operate it however you see fit after you read the manual.
Adams Tender / Magnolia Trailer (A55301)
Adams Tender /...
2001 STERLING DUMP TRUCK (A54756)
2001 STERLING DUMP...
2007 STERLING T/A DUMP TRUCK (A51406)
2007 STERLING T/A...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2018 FREIGHTLINER BUCKET TRUCK (A51406)
2018 FREIGHTLINER...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
