OK to use Float to lower bucket?
   / OK to use Float to lower bucket? #11
I don't see any issue as long as you aren't loaded. They drop pretty slow in float with no load. For that reason I rarely do it. Only time I do is if I want to be in float when it hits the ground. But if just lowering for any other reason, I do not.
   / OK to use Float to lower bucket? #12
I think it depends on the tractor / loader combo . both of my tractors drop the bucket like a rock in float -even empty so in my cases it is a no no. Sounds like the Kubotas have some kind of flow resticter in the float circuit??
   / OK to use Float to lower bucket? #13
Good to know, I've been letting it drop while in float too....I did notice it is slower retracting and can hear the hiss from flow restriction internally
   / OK to use Float to lower bucket? #14
Ditto.
It must be some flow restrictor that kubota puts in there if other makes are dropping much quicker in float.
I just assumed that since there wasnt much weight on there is why it was slower, vs the hydraulic pump forcing it down quickly.
   / OK to use Float to lower bucket? #15
My LS drops at about the same speed in float as in powered down. Like KOua, I only use float to lower when I am going to use it in float, after all, you have to move the lever more to get to float so why waste the motion.
   / OK to use Float to lower bucket? #17
Do you have the valve schematic for your tractor. I suspect that in the "Float" position Ports " A", "B" & Tank are connected. Pressure continues to flow out the power beyond beyond port. While in float The oil being forced out of the base end of the cylinder is directed to the rod end and the excess flow is directed to tank. To prevent cylinder rod end cavitation the spool could be made to provide some increased flow restriction to tank while in the float mode.
my :2cents:
   / OK to use Float to lower bucket? #18
my :2cents:
I normally can read hyd schematics but mobile equipment valves for me can be confusing
I see no restrictor in the loader valve itself
   / OK to use Float to lower bucket? #19
WDCHYD,
You are correct the schematic does not show any restrictions but it does indeed show that "A", "B" & "T" are are all common while in float(position closest to the handle). Most valve bodies the center port is pressure, ports on either side of center are the "A" & "B" ports while the two end ports are Tank lines. Whistling oil noise could be from the oil being ported from one end of the spool - casting assembly to the other via the tank core connection.
Attachment below is a sectional view of a Husco 9210 loader valve. It may help show the oil path during float.
thanks for posting the schematic. picture is word a 1000 words.
   / OK to use Float to lower bucket? #20
On my NH Boomer the loader drops so fast that if you didn't know any better you would think no hydraulic fluid was being moved at all. I try not to go into float unless I've got the bucket no more than 6" up off the ground.
xtn
2001 Acura MDX SUV (A53424)
2001 Acura MDX SUV...
2002 CATERPILLAR 938G WHEEL LOADER (A51406)
2002 CATERPILLAR...
2013 UTILITY VS2RA REEFER TRAILER (A54607)
2013 UTILITY VS2RA...
2024 New Holland T8.410 MFWD Tractor (A55302)
2024 New Holland...
(APPROX 15) 2" X 6" X 68" TUBING (A54756)
(APPROX 15) 2" X...
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
