Electrical distance and wire size question
/ Electrical distance and wire size question #1
C4Ranch
Eastland Co, Texas
Kubota L5240 HSTC
Ive spent a couple hrs trying to look this up on the web and couldnt find a good answer.
I'm thinking about rewiring my property to eliminate one of the two meters while at the same time wiring up a recently drilled deep well.
Here is the setup. 3 buildings in roughly a straight row about 300' from each other.
Small Barn <- ~300' <- equipment barn & well -> ~300' -> house
Was thinking about having a meter put in the middle by the equipment barn then running 2 independent runs around 300' each underground to each building.
Question, what size wire would be needed and at what distance/wire size does it become cost prohibitive to go up in wire size?
Tia!
J
/ Electrical distance and wire size question #2
You need to know your service sizes in amps, before you can make any calculations..
/ Electrical distance and wire size question #3
Depends:
Is this a single phase, 240V systems?
What amperage to each building? i.e. what is main breaker in each building?
Copper or aluminum wire?
Above ground aerial or underground, direct bury or in conduit?
Is the utility involved? Will they make you put a disconnect switch, or switches, at the meter?
/ Electrical distance and wire size question #5
Well without having info as to the amps, ill give the following observations that i use every day of my working career.....electrical contractor.
I have installed lots of 400 amp services, 240 volt single phase systems up here over the years. Usually we run one 200 amp feeder from meter to shop, and one 200 amp service to house. I almost always calculate this as needing 2-1/2" conduit runs and 250 MCM aluminum feeder wires to each building. This allows for minimal voltage drops around 3.6%
also, just to know the price to increase from 4/0 to 250 mcm isnt very much, but does require a larger conduit.
heres a site you can look at Voltage Drop Calculator
/ Electrical distance and wire size question #6
Thanks! I will have to look when I'm out there next weekend.
It's an average size house, 1 AC/heat pump, hot water heater, electric stove/oven, electric washer/dryer, 3 bedroom with an extra 240v hookup for aux water pump.
The barn is less, refer, lights, plugs, aux water pump and RV plug.
Will be buried.
/ Electrical distance and wire size question #9
Depending on how reliable your power is, or if you ever thought a about a generator, but you may want to consider that now would be the best time to put in a transfer switch and genset connection point.
/ Electrical distance and wire size question #10
What is your base fee for the meters? You could spend thousands trying to save $100 a year in base meter fees.
Yep, that's exactly why I want to price it out first. My base fee per meter is $22/mth/meter. So by cutting one, I'd save $264/yr plus the benefit of removing the unsightly power pole next to the house.
I have to wire up the new well regardless so im gonna have to trench and run 300' in one direction no matter what.
/ Electrical distance and wire size question #12
Will be buried.
Thats hefty house drain. Looks like the primary feed should come to the house. Then run 6Ga direct burial to outbuildings.
/ Electrical distance and wire size question #13
Normally if the well is feed from house panel, there's a breaker in the house panel protecting that cable. If you feed it from the meter you will need a breaker or fused disconnect devoted for this service located either at the meter or the well house. Depending on what your utility requires. Same is true for the other building
/ Electrical distance and wire size question #14
Here is a long thread about wiring my barn - http://www.tractorbynet.com/forums/projects/139326-450-wiring-conduit-how-assemble.html You don't need to read the whole thing. The best advice I got was from the utility company engineer. He came out for free and helped me determined what I needed. It was more than telling me what they required. I'd at least give them a call to see what there requirements are and to see if they would send someone out to look at the project.
Good luck!
/ Electrical distance and wire size question #15
Good luck!
Big ditto on that, I had the same experience. He just casually said let's pull the power off a different pole to make the routing through trees easier, I didn't think that was an option. He told me what parts of the job I could do myself, I ended up burying the conduit, that saved $1500 off their price.
/ Electrical distance and wire size question #16
I'll third that remark. We have a larger multi-state company, but the design engineer has been great to work with. We are in the process of building the new house and the closest pole was ~ 900 feet away. The engineer came out and walked 5 different routes with me to figure out one that would be beneficial to us both. Now I don't have the service in now, but the trenching is done and I know exactly what is expected, boxes, meter, wire, and such. For me I buried the main run to a transformer location the I'm setting the meter and box beside the transformer. Then I'm trenching 100 feet to both the house and someday the barn with only one meter fee. I'm not 100% sure if the well will feed from the house or from the transformer but I have options. I hope my rambling help.
/ Electrical distance and wire size question #17
I would kill two birds with one stone (if allowed by the electrical company/inspector) and get a meter base with a full power pass-through panel (such as: GE Power Mark Gold 200 Amp 20-Space 40-Circuit Meter Socket Load Center-TSMR2020CSCU at The Home Depot ) then add a interlock it (such as: GE PowerMark Gold Load Center/Generator Interlock Kit-THQLLX1 at The Home Depot ).
That would give you a 200 amp feed to the house and 40 spaces for feeding the well, the "Equipment Barn" and the "Small Barn" for around $220 (plus tax).
Aaron Z
Took the advice and met with my elec coop about relocating the pole near the middle between cabin and barn.
Below is a recap with answers from electric coop, sound about right?
Planning on running the existing 200amp svc to house (~150' up hill) and to barn/RV plugs which is about 270' away.
Questions:
1. Will this configuration allow 200amp svc to house and barn simultaneously?
Yes
2. Can I also run from pole directly to water well?
Yes, to a breaker for water well. Breaker can be under the disconnect on our pole or if you build a well house I would put the breaker in the well house.
3. Is this the right kind of wire? Not clear what URD means.
http://m.homedepot.com/p/Southwire-...eetbriar-Wire-By-the-Foot-55418499/205001902/
Yes, the URD is Underground.
4. What size conduit should I get?
Will fit in 2" but 3" is easier to pull through.
5. Will 4/0 4/0 2/0 be sufficient for the Barn at ~270'?
Yes, you will have voltage drop at 270' but you are sending 200 amps per leg from meter to barn. If you balance your load you will have plenty of voltage for barn and a couple RVs
Thanks for all your help!
J
