Rear Blade Rear blade for snow
/ Rear blade for snow
Went out to TSC and looked at the one they had in stock. It was nice but for some reason I decided to drive down the road to a Fleet Farm. Hate that place :) they had one there a KK for the same price. It was 50 pounds heavier and had a stand. Not that I need the stand but the extra weight I thought was worth it. Brought it home and plowed my driveway and two neighbors.
I am extremely happy with it. We got 6" of snow last night with dome good drifts. The blade lifter some so will probably add some weight to it.
/ Rear blade for snow #22
Glad it worked out! We have a old blade that still works well! The slots are worn out, so the blade moves a lot. It is quite possibly 20 years old if not older. We have used it extensively for a 1/4 mile driveway and even have used it and angled it way down on one side like a one bottom plow to plant trees. Even the worst quality will get you several years of life! You have a good quality and only plan to use it to move snow so I think it will last a very long time for you! I went to our tsc to look at implements and they were sold out of them and everything else related with snow like I said. Sometimes it is better to use a back blade in tighter spaces and to use one on short driveways. If your tractor is 4 wheel drive you will have less chance of being pulled sideways. That has been the weakness with our 2 WD tractors. Enjoy
Well I do have 4 wheel drive but I am probably going to need chains. If on the level I am ok but do get pushed around a little bit. If I have any up climb I am screwed. I have the R4 tires and never been really happy with them on concrete.
So next purchase will be chains the are designed for concrete.
/ Rear blade for snow #25
I have had my jd 110 for about a year now. I had some concerns about traction with r4 tires but with the 4-wheel drive and the concrete driveway. I have not had a problem with snow.
I bought the blade used its a 6-way blade made by Bush Hog model 91-08 (same as Dirt Dog 91-08 & Rhino 850), (I also have a fel for the heavy snow).
The blade is 8 ft and weights about 850 lbs. It has hydraulics for the angle. I plan on adding a hydraulic cylinder for the right or left offset.
The photos below are from last year, before I added the blade
I will try to add some more photos of the tractor & the blade next time we get some snow
/ Rear blade for snow #26
/ Rear blade for snow #27
Greg, when you say slotted pipe over the cutting edge are talking PVC or Steel pipe and what diameter and does it stay in place with no fasteners?
Thanks.
Greg,
I'm also curious about what pipe your using? I have an RBT 4096 that's just under 1k lbs or so and notice that it almost scrapes TOO good on the pavement, I'm scraping up pieces of my driveway (my driveway is old and cracked not nice and smooth). I do have skid shoes as well and haven't messed with those yet, only used the blade on one storm so far. Tomorrow will get another use and I'll try the skid shoes, but the pipe idea is interesting. I LOVE the full hydraulics!
/ Rear blade for snow #29
Odonnks and Piston,
I used 2" black pipe (steel) on the cutting edge of my rear blade. I have 2 tabs welded on the back side of the slotted pipe that are fastened to 2 of the bolts that hold the cutting edge to the mold board. I'll post a picture when I get home. Another thing is that after a couple of seasons of plowing my 550 feet of driveway and 1/2 mile easement is that the pipe started to wear out. The gravel acts like sand paper. So then I took a piece of 2 1/2" black pipe and cut it in half the long way with a plasma cutter and stitch welded it to the original 2" black pipe. It was a perfect fit and I have a spare piece for when this one wears out in a couple of years.
Piston, you're right, with blades that are heavy like ours, they will definately get right down to the surface. That is where the skid shoes come in handy. I just lengthen the top link and rock the blade back onto the skid shoes a bit to take as much pressure off of the pipe as I need. If my gravel starts thawing and coming up when I plow, I lengthen the top link until I have a 1/2" gap between the pipe and the drive. I also do this if my drive turns to ice because that little layer of snow that is left gived me traction.
/ Rear blade for snow #30
I ended up picking up a TSC 6' blade before a snow storm hit Tuesday night. Was very tempted to wait and buy a good $800-1000 blade with tilt/slide/etc, but in the end the $350 blade at TSC won out because of availability, and I wasn't sure I'd ever use it for anything but snow so the basic features are OK.
We only got 4" (plus some drifts) but the blade worked great and saved a lot of hassle on my 700' gravel driveway. Even though temps never got above 20F yesterday, most of the driveway melted clear with sunlight by late afternoon thanks to the plowing (in contrast, our unplowed roads are a dam frozen mess right now and won't likely clear up until the weekend when it gets warmer).
I started with the FEL bucket down and pushing, but found I did just as well with it up and just using the rear blade. That may change with deeper snow. Also plowed without chains, and had no issues (driveway mostly flat, only a slight incline in one spot). In fact, for clearing in front of the garage, I put the tractor back in 2WD to gain better maneuverability! That may also change if we got more snow.
I used 1" PVC pipe over the cutting edge on the gravel driveway, and it worked great but wore through from making just three passes down the driveway. So I will need to do something more durable, or plan on replacing the pipe frequently. On the paved section near the garage, I got better results without the pipe in place. If I put on skis or skid shoes, I'll probably need to make them easy to flip out of the way.
/ Rear blade for snow #31
Here's a few pics of how I mounted my pipe. I did get 2 slightly longer bolts for bolting it on.
/ Rear blade for snow #32
How did you end up slotting that metal pipe?
/ Rear blade for snow #33
Greg, thanks for the description and pictures.
Has anyone here attached 1-in thick horse stall Matt to extend 4 or 5 inches below the cutting edge?
My driveway is 2,500 ft gravel covered with a bit of a hump in the middle.
Any solid straight surface will remove snow from the hump and leave it in the tracks.
Was thinking of stall matt in three pieces with the center a bit higher.
Thank you again!
Kevin
/ Rear blade for snow #36
Thcri your next purchase should be a snow pusher. WR Long makes them in both 60" and 72". You'll be done in half the time or less with one.
/ Rear blade for snow #38
OP-
I just wanted to let you know that a lot of the "riding up" on the snow by the blade can be eliminated by adjusting the top link longer to angle the cutting edge forward and down which makes it cut in a lot better.
OP- I just wanted to let you know that a lot of the "riding up" on the snow by the blade can be eliminated by adjusting the top link longer to angle the cutting edge forward and down which makes it cut in a lot better.
I was wondering if adjusting the top link would help. I know right now it is as short as it will go. I shall move her out some
/ Rear blade for snow #40
If you are grading gravel or topsoil and want to move it and spread it at the same time, shortening the top link will angle the cutting edge back and down and do a much better job. Just the opposite of what works well for cutting into hard packed snow or dirt. The first drags the dirt/snow and spreads it out into shallow dips etc, the second cuts into and basically shoves the dirt/snow forward more.
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2008 International 4300 Altec LRV60-E70 70ft Forestry Bucket Truck (A61568)
2008 International...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
2019 John Deere 1023E Tractor (A61166)
2019 John Deere...
2013 NEW HOLLAND WORKMASTER 35 TRACTOR (A62130)
2013 NEW HOLLAND...
UNUSED WOLVERINE TQH-26-02C 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
