Rear Blade Rear blade for snow
/ Rear blade for snow #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
For years now I have plowed snow with the front bucket with my TC29D and has worked fine. Well until we get the higher snow falls the bucket overfills too fast and I have to go over it too many times.
I was thinking of getting a back blade. The back blade would be nicer for pulling the snow away from the buildings and garage doors rather than pulling back with Murphy loader. And as snow falls out of the bucket from overfill the blade could pick it up.
My bucket is larger than recommended right now at 72" because I use it mostly with snow. If I use it for dirt that pucker factor kicks in too much for my comfort. Snow no issue.
So if I get a blade do I get a 72" or go up to the 84"? At 72" the overspill would not get picked up as much as the 84"
Thoughts
/ Rear blade for snow #2
Thoughts
A blade works much better than a bucket.... You will probably use the blade exclusively except for piling snow.
Base the blade length off your rear tire width. You want to be able to cover the rear tire width with the blade angled. A long blade could hit the tires, and when you fill with snow it will act like a rudder and turn the front of the tractor. With a 8' blade on my L3650, it will easily push the front of the tractor where it becomes an issue. This is on gravel, if you have a clear concrete driveway it may be better.
Plan on chains for the front tires.
/ Rear blade for snow #3
BTW, 72" is a big bucket.. My skid loader takes a 68" bucket and the tractor takes like a 66". 72" on a TC29 seems like a lot!
/ Rear blade for snow #4
Don't forget!! 72 inch blade turns into 60 when angles +/-
8 foot turns into 7 and etc.
I grew up with back blades. Put one on a tractor that gets great traction and you'll love it! Can be used for other things besides snow.
The more heavy duty blades are better. They hold up longer and are more reinforced. Sometimes they move snow better due to the curves/ height of the blade. For not much more money you can get a better blade. It is a perfect idea to get a blade on the 3 pt with the loader on front. Can work all day without turning around... well almost :p
/ Rear blade for snow #5
Pick rear blade length at 45 degrees will over lap rear tires but not hit rear tires,purchase heavy duty blade tho.
/ Rear blade for snow #6
The heavier the blade the less likely you are to have deep snow cause the blade to ride up on top of the the snow every twenty feet or so. A 50-07 bush hog blade would be a good one used it on my 3520 with great success. The blade weighed about 475 lbs or you could go to a 50-06
/ Rear blade for snow #7
I use a 340 pound 7' KK on the back of my L3240 which has tires set at 63" to the outside sidewalls. It's long enough to cover the rear tire track when angled all the way, but it's short enough that I can spin it 360 on the 3PH. The only time I use the bucket is for piling snow that is to high for the blade to move - like the town plow leaves in front of the entrance to our field. Heavier is better & hydraulic if you have the remotes and $ for it! TNT makes my manual rear blade much more useful, too.
/ Rear blade for snow #9
I think an ideal setup would be a plow bade for the FEL, and a back blade for the 3pt. I have a plow on my truck, but like the back blade on my tractors for pulling snow away from buildings etc. I typically pull the snow to where I can then push it with the plow....works really well. If I ever get around to it, I may try to make an adapter so I can use my existing plow (7.5') on my FEL....then I wouldn't have to bother with taking it on and off my truck.
I recently ordered a new 8' EA XTreme 6 way blade because my old blade was for my smaller tractor (sold it), and wasn't wide enough when angled (only 6').
/ Rear blade for snow #10
I have a 7 ft bucket and a 7 ft back blade i use both at the same time works great.
Good thought. Not much difference in price between the two either. Probably will pick one up tonight.
/ Rear blade for snow #12
Rear blades work well.I use a 50-70 Bush-Hog and a 8ft.Curtis in the front.
I don't think I need anything extremely heavy duty. Heavy yes to keep the blade down but I won't be doing any dirt or gravel at least not that I know of. I found this pretty inexpensive one at Tractor Supply. Has anyone had any experience with this brand or line?
CountyLine® Grader Blade, 7 ft. W - Tractor Supply Co.
/ Rear blade for snow #14
Have you consider auctions etc. there times you can get really nice back blade for half price.
/ Rear blade for snow #15
I was thinking he might be getting so much snow his way and is tired of using only a bucket he might want to buy his 3pt plow ASAP so he can clear everything faster and easier. Its so unfortunate what we don't get done before winter hits.
/ Rear blade for snow #16
I have the 5' version of this very blade behind my little JD2305. With the rubber stall mat cutting edge this has proved to be a very versatile implement for several years now. We don't get the snow you do, however!
Good Luck.
/ Rear blade for snow #17
diesel lover.
I agree,more so if drifting snow.
/ Rear blade for snow #18
I just sold my 7 ft king kutter rear blade it weighed 340 lbs.bought a new woods 8ft blade I believe the weight is around 680 lbs.It has a side link to off set it IMHO a very handy feature.
/ Rear blade for snow #19
This set up works awesome for me. 7' blade, all hydraulic with a piece of slotted pipe over the cutting edge.
/ Rear blade for snow #20
The county line brand at tractor supply is a good brand! It will do everything you are looking to do in a pinch! I was just at tractor supply shopping around and found that they had sold out of everything.... that is everything related with moving snow haha. All back blades sold out, looped tow straps sold out, even the 6 inch and eight inch. I hope you can still buy a blade at a decent price!!
New/Unused ATS-ECP40 Plasma Cutter (A61166)
New/Unused...
2008 Freightliner B2 Bus, VIN # 4UZABRDJ98CZ17952 (A61165)
2008 Freightliner...
UNUSED 250 GALLON FUEL TANK (A62130)
UNUSED 250 GALLON...
2015 TRANSCRAFT DTL300 48X102 TRI/A DROP DECK TRAILER (A59909)
2015 TRANSCRAFT...
UNUSED RAYTREE RMDM72S - 72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61567)
2025 Kivel 48in...
