Twenty two year old hy-trans fluid
/ Twenty two year old hy-trans fluid #1
Rock knocker
Sno WA
JD 950
Four gallons in a five gallon pail, top always screwed on and kept inside. Keep and use in the future, or recycle?
/ Twenty two year old hy-trans fluid #2
Your best bet would probably be to recycle and buy some fresh fluid. The additives break down within around 5 years after manufacturing. It will work, just not worth it in the long run.
-Dominic
/ Twenty two year old hy-trans fluid #3
If it has never been opened and you do decide to use it I would shake it up real well. The additives will settle to the bottom. I've had luck asking my local hardware store to put all sorts of things on their paint can shaker.
/ Twenty two year old hy-trans fluid #4
What would you be using it in? New HST, no. Old gear, yes.
Servicing a 83 JD 950
2019 John Deere M15 Batwing Mower (A66285)
2019 John Deere...
Bush Hog 285' 3Pt Mower (A66285)
Bush Hog 285' 3Pt...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
Striker Slide in Spreader Box (A62679)
Striker Slide in...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
