Twenty two year old hy-trans fluid
   / Twenty two year old hy-trans fluid #1
Rock knocker
Sno WA
JD 950
Four gallons in a five gallon pail, top always screwed on and kept inside. Keep and use in the future, or recycle?
   / Twenty two year old hy-trans fluid #2
Your best bet would probably be to recycle and buy some fresh fluid. The additives break down within around 5 years after manufacturing. It will work, just not worth it in the long run.
-Dominic
   / Twenty two year old hy-trans fluid #3
If it has never been opened and you do decide to use it I would shake it up real well. The additives will settle to the bottom. I've had luck asking my local hardware store to put all sorts of things on their paint can shaker.
   / Twenty two year old hy-trans fluid #4
What would you be using it in? New HST, no. Old gear, yes.
Servicing a 83 JD 950
2013 Dodge Durango (A53317)
2013 Dodge Durango...
30in Hydraulic Forks Skid Steer Attachment (A56857)
30in Hydraulic...
1995 Freightliner FLD120 T/A Wet Kit Day Cab Truck Tractor (A55973)
1995 Freightliner...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
