Twenty two year old hy-trans fluid
   / Twenty two year old hy-trans fluid #1
Rock knocker
Sno WA
JD 950
Four gallons in a five gallon pail, top always screwed on and kept inside. Keep and use in the future, or recycle?
   / Twenty two year old hy-trans fluid #2
Your best bet would probably be to recycle and buy some fresh fluid. The additives break down within around 5 years after manufacturing. It will work, just not worth it in the long run.
-Dominic
   / Twenty two year old hy-trans fluid #3
If it has never been opened and you do decide to use it I would shake it up real well. The additives will settle to the bottom. I've had luck asking my local hardware store to put all sorts of things on their paint can shaker.
   / Twenty two year old hy-trans fluid #4
What would you be using it in? New HST, no. Old gear, yes.
Servicing a 83 JD 950
Enmark Z Spray (A53316)
Enmark Z Spray...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
