Twenty two year old hy-trans fluid
/ Twenty two year old hy-trans fluid #1
Rock knocker
Sno WA
JD 950
Four gallons in a five gallon pail, top always screwed on and kept inside. Keep and use in the future, or recycle?
/ Twenty two year old hy-trans fluid #2
Your best bet would probably be to recycle and buy some fresh fluid. The additives break down within around 5 years after manufacturing. It will work, just not worth it in the long run.
-Dominic
/ Twenty two year old hy-trans fluid #3
If it has never been opened and you do decide to use it I would shake it up real well. The additives will settle to the bottom. I've had luck asking my local hardware store to put all sorts of things on their paint can shaker.
/ Twenty two year old hy-trans fluid #4
What would you be using it in? New HST, no. Old gear, yes.
Servicing a 83 JD 950
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
1999 John Deere 5410 (A64126)
1999 John Deere...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
