Oil & Fuel Satoh Bison 650G questions.
/ Satoh Bison 650G questions. #1
twoshoes
OWENSVILLE, INDIANA
SATOH BISON 650G
Hello. New member here. I just bought a Satoh Bison 650G with a front end loader. I am needing to know how to check the PTO oil and transmission/hydraulic oil and fluid levels in it. I see filler caps but no site glasses. When I pull the filler caps don't see any oil inside. I also read online somewhere about checking the governor oil in it. I also need to know what type of fluids to add to it. I am looking for another Satoh 650G owner with info. Thanks.
Tim.
/ Satoh Bison 650G questions. #2
Hello and Welcome
The site The Satoh S650G Bison Tractor Information Resource will give you all the fluids and capacities.
The governor has a dip stick on the fill screw. The drain hole is right straight below it.
The trans/pto uses 80/90 gear oil filled to the plug by the left foot board.
The hydraulic Filter is on the right lower below the seat. Big plug is filter little one is drain plugbison oil 012.jpg
Hope these help. Good Luck with the Bison.
Lee
Thank you Lee for the info and great pictures. It all matches mine exactly except there is no drain plug beside the fluid filter on mine like there is in your pic. I will look further for another drain plug tommorrow. You have been most helpful, thanks so much.
/ Satoh Bison 650G questions. #4
Glad it helped. If you take out the filter plug it will drain...trust me...lol
Lee
/ Satoh Bison 650G questions. #5
Lee,
Thanks for the informative web site on the satoh mitsubishi. I have a mitsubishi Satoh S650G and a satoh Bison. The Bison I just purchased here recently. Lots of little things to take care of. My question for you? The web site previously mentions as to the capacity of the governor housing. States " .04L or .0704 pt. . I know this is a small amount, but in laymans terms about how much is this?
Perhaps how many thimbles full? I realize add some then check the dipstick.
This is my first post so please be patient and bear with me if you would.
Thank you in advance!!!
/ Satoh Bison 650G questions. #6
Everything is in metric sizes, so you have to run the figures on a converter to get our civil figures!---I have an s-650-g also and they are good tractors,---just hard to work on! thanks; sonny580
/ Satoh Bison 650G questions. #7
I use a syringe to measure and fill my governor. Book says 40cc and with my syringe I am full with 50ml.
/ Satoh Bison 650G questions. #8
thanks guys (Sonny 580 and knothead541) with the info on the govenor. I like the idea with the syringe.
And now.... back to work on the next problem
Lee,
By using an online conversion chart you can convert liters to ounces. 0.4 liters = 13.5226 ounces. So that is just slightly over 13 1/2 ounces. Hope this helps and good luck with the new Bison 650G. I love mine, its a sweet little tractor!
/ Satoh Bison 650G questions. #10
Twoshoes, I'm new on here and right up the road from you. I've recently bought what I believe to be an '8?'s s-650g with a Woods finish mower and grader blade on front, and while I've had a bit of minor problems it seems like its a solid tractor. What year is yours, pics?
Hello rredman. Yes I see we are very close $T2eC16d,!)sE9swm,vw)BRSP1O1zlw~~60_57.jpgneighbors. To the best of my knowledge mine is a 74 to 76 Satoh 650G with a front loader and rear blade. It has been a sweet lil tractor. Have moved a lot of snow with it in the past week. I will try to post pics but not sure if it will work..$T2eC16d,!)sE9swm,vw)BRSP1O1zlw~~60_57.jpg$T2eC16d,!zcE9s4g3hwjBRSP0fOsLg~~60_57.jpg$T2eC16F,!w0E9szNW4rSBRSP1FLO9g~~60_57.jpg$T2eC16h,!yEE9s5jHQH5BRSP1ZFF8g~~60_57.jpg$T2eC16J,!w0E9szN((cJBRSP0)wRDQ~~60_57.jpg$T2eC16J,!zUE9s38-IjfBRSP07dDtw~~60_57.jpg1.jpg2.jpg3.jpg
/ Satoh Bison 650G questions. #12
Nice looking Bison twoshoes:thumbsup:
Lee
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
PT 6' Dirt Pan (A64127)
PT 6' Dirt Pan...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
New, Landhonor Skid Steer Pallet Fork  (A62679)
New, Landhonor...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
