Chimney (thimble height)
/ Chimney (thimble height) #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
does anyone know a good height to locate a thimble in a new chimney for a 6" stove pipe
/ Chimney (thimble height) #2
High enough that any stove would fit under it with room for the elbow, not just the one you have now.
Low enough that you don't catch the ceiling on fire. :laughing:
You will get some heat off the flue pipe if you leave some exposed above the stove before it turns into the thimble.
/ Chimney (thimble height) #3
Put it at any height that is useful for you. Remember to leave at least 3x the diameter of the stovepipe as clearance to any combustible surface. (6" stovepipe needs 18" clearance to ceiling, for instance)
/ Chimney (thimble height) #4
put it at a height so your stovepipe connections can all be made without having to customize the pieces.
/ Chimney (thimble height) #5
/ Chimney (thimble height) #6
depends on where its at in a barn high as possible to reclaim lost heat , in a house would depend on type of stove
Grate Advice, Thanks much for the replies. more pipe in the living space means more heat correct. And staying a minimum of 18" for standard safety.
dave 1949 the klein crimpers are for stove pipe and will they work on residential gutter
