Wood, Coal or Pellet Stove Corrosion During the Off Season
   / Wood, Coal or Pellet Stove Corrosion During the Off Season #21
I don’t know how long LEDs last in actual use. I can just say that I’ve never had one burn out.
Maybe our builder just used cheap LED's. 6 in 3 years are out.
And the cheap arc fault GFCI breakers. Changed 3 so far due to refrigerator popping them. Still used arc fault GFCI, but Homeline vs. Siemens
   / Wood, Coal or Pellet Stove Corrosion During the Off Season #22
I am in the trucking industry where LED's have been in play for years. Subjected to vibrations shock and salt roads, they don't last nearly as long as advertised!
David from Jax
   / Wood, Coal or Pellet Stove Corrosion During the Off Season #23
I had my kitchen remodeled 10 years ago or so, and the arc fault breakers they used to comply with current code were a royal pain. I ended up replacing them with non arc fault breakers.
   / Wood, Coal or Pellet Stove Corrosion During the Off Season #24
is the inside of the flu pipe connection flush and do you have access to it? If so, putting a piece of sheet magnet across the opening might do the trick.
Yes, it's flush but that would require removing the flue pipe, which I'm trying to avoid.
Now, after the pipe has been removed, I just stick a plastic bucket in the chimney thimble.
16' 5" METAL STORAGE RACK (A60432)
16' 5" METAL...
(32) 8" FLOOR TRUSSES (A60432)
(32) 8" FLOOR...
2022 Ford F-150 Pickup Truck (A59230)
2022 Ford F-150...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
2021 Nissan Versa Sedan (A59231)
2021 Nissan Versa...
