Wood, Coal or Pellet Stove Corrosion During the Off Season
   / Wood, Coal or Pellet Stove Corrosion During the Off Season #21
I don’t know how long LEDs last in actual use. I can just say that I’ve never had one burn out.
Maybe our builder just used cheap LED's. 6 in 3 years are out.
And the cheap arc fault GFCI breakers. Changed 3 so far due to refrigerator popping them. Still used arc fault GFCI, but Homeline vs. Siemens
   / Wood, Coal or Pellet Stove Corrosion During the Off Season #22
I am in the trucking industry where LED's have been in play for years. Subjected to vibrations shock and salt roads, they don't last nearly as long as advertised!
David from Jax
   / Wood, Coal or Pellet Stove Corrosion During the Off Season #23
I had my kitchen remodeled 10 years ago or so, and the arc fault breakers they used to comply with current code were a royal pain. I ended up replacing them with non arc fault breakers.
   / Wood, Coal or Pellet Stove Corrosion During the Off Season #24
is the inside of the flu pipe connection flush and do you have access to it? If so, putting a piece of sheet magnet across the opening might do the trick.
Yes, it's flush but that would require removing the flue pipe, which I'm trying to avoid.
Now, after the pipe has been removed, I just stick a plastic bucket in the chimney thimble.
2011 Mercedes-Benz E550 Sedan (A51694)
2011 Mercedes-Benz...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
22016 (A51694)
22016 (A51694)
