Drill Bits - What is best?
   / Drill Bits - What is best? #1
Egbert
Alaska
JD LX188
OK, which is it?
Black Oxide
High Speed Steel
Cobalt
Titanium
Which keeps its edge the longest?
Does brand matter?
   / Drill Bits - What is best? #2
I think titanium is a coating as is black oxide. When the coating wears off so does the advantage. High Speed steel for general purpose work in steel. Cobalt is much harder than high speed steel, will hold an edge longer, but is brittle and breaks easily, and is more expensive. High speed steel for me.
   / Drill Bits - What is best? #3
yes, hss and cobalt are materials, the others are coatings. Cobalt is good if you are using it in a fixture in a drill press or or mill, for hand drilling stick to hss. Titanium coating is overrated IMHO, black oxide finish is fine... unless you are drilling aluminum- then it sticks and gums up. To be honest, I usually just prefer plain "bright" finish hss bits. Money is better spent on quality bits than on finishes. Try to buy Cleveland or Chicago-Latrobe (there are probably other good ones too).
If you want to buy cobalt, be aware that there are different grades, IIRC m35 is 5% cobalt and m42 is 8% cobalt.
   / Drill Bits - What is best? #4
The best basic drill bits are Chicago-Latrobe, cobalt M42, split point. Nachi makes an excellent drill in a black oxide coating with split point.
There are better, more expensive drills for different materials.
   / Drill Bits - What is best? #5
I run cobalts at my home shop for all the common sizes, such as 3/16, 1/4 etc. Generally have HSS for the other 160 or so sizes.
At work (aircraft Sheetmetal guy) pretty much all cobalt.
Drill bits are a tool like any other, and in short, you get what you pay for. Sometimes it is money well spent to have quality, and sometimes, especially for limited use, the cheaper ones are fine. Even at that, I like to still buy quality.
   / Drill Bits - What is best? #6
Conditions have to be right for cobalt. Proper speeds, feeds, and rigidity. Putting a cobalt drill bit in a cordless drill will be sure to disappoint. Cleveland, in my opinion, makes the best HSS drill bits.
   / Drill Bits - What is best? #7
High speed for general use @ 118 degree drill point angle most steels @ 135 degree drill point angle for most nonferrous metals (brass, bronze, copper, aluminum, etc.).
Cobalt for any Stainless Steel and Cast Iron (you can thank me later).
Solid Carbide (not masonry style blade tipped) for the rare instance you want to drill into ballistic steel like HY100 or similar.
And.... most importantly.... the correct lubricant for the type of material you're drilling into.
   / Drill Bits - What is best? #8
Agreed. A good cutting oil will greatly extend the life of your drill bits when cutting metal.
Can the cobalt bits be sharpened? I know lots of folks like their Drill Doctors.
   / Drill Bits - What is best? #10
With the correct grinding wheels. We had different wheel for HSS and Carbide.
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52128)
2020 New Holland...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
1041 (A50459)
1041 (A50459)
Quick Attach Pallet Forks (A47384)
Quick Attach...
