Need help deciding on a grapple
/ Need help deciding on a grapple #222
/ Need help deciding on a grapple #223
I need to find one of those on craigslist. What all are they called? crane scale, hanging scale????????????
crane scale, found it on eBay.
/ Need help deciding on a grapple #224
Man, that Gorilla Grapple looks like one seriously overbuilt (in a good way!) piece of equipment. If I had something with the power of your Telehandler, I'd want one of those grapples.
/ Need help deciding on a grapple #225
crane scale, found it on ebay.
Could you hook it to a tree and pull against it to see how much something would pull as long as you did not exceed the scales max weight?
/ Need help deciding on a grapple #226
Could you hook it to a tree and pull against it to see how much something would pull as long as you did not exceed the scales max weight? Or the tree doesn't break! :laughing:
Yes, in fact I was going to do that with my Polaris EV, just to find out what it would do.
/ Need help deciding on a grapple #228
You need to compare it to something:D
Guess I could compare it to my car! :D
/ Need help deciding on a grapple #229
/ Need help deciding on a grapple #234
Man, that Gorilla Grapple looks like one seriously overbuilt (in a good way!) piece of equipment. If I had something with the power of your Compact Telehandler, I'd want one of those grapples.
Telehandlers are much bigger!
This is why I got it:
My first clamshell style grapple would not penetrate a cedar tree because of the bracing between the tines. To pick it up, you had to maneuver around to get the grapple parallel to the trunk.
My second grapple is the ideal design (no bracing between the tines) to penetrate the cedar tree from any any angle, and pick it up. Much faster when stacking trees.
44" wide, single lid.
Will grab a big cedar from any angle.
N
o bracing between the tines allows it to grab it in line with the trunk.
Pulled this dead, leaning over willow tree.
Handles the big long time dead, long trees also. :thumbsup:
/ Need help deciding on a grapple #235
Well, since this thread is derailed, I will post this experiment.
I decided to find out how much drawbar pull the EV has. I hooked the crane scales to what was left of a small tree at the edge of the pond. The beavers had chewed through it many years ago, but it was still growing.
As I started pulling in turf mode, I could feel the left rear tire slip, then the right rear slip. I switched to AWD and the chain tightened again, but even though the the wheels were spinning a little, I was moving forward. I stopped, got out and took a picture.
The tree roots were coming out of the ground! :eek:
This is the surface that I was on.
I went ahead and pulled it all the way out. :thumbsup:
If anyone asks me "how much can it pull?", for now I will say "enough"
Now maybe shibaura_4043 will come back an get this back on track with an update :D
"If anyone asks me "how much can it pull?", for now I will say "enough" "
Now maybe shibaura_4043 will come back an get this back on track with an update :D[/QUOTE] "
Im intrigued... Ill be the first to ask in hopes of a real answer :laughing: How much can it pull??
Well my "grappling" is on hold until I finish my SSQA(should finish Sunday)but once Im back in business I'll post a few before and after pics:thumbsup:
/ Need help deciding on a grapple #237
Going to have to wait until it warms up some. Yesterday winter arrived, high was 61, dropped to 30 at midnight.
Now it is: Overcast 28, Humidity 72%, Wind Speed N 13 G 22 mph, Wind Chill 17. :thumbdown:
yeah that front hit us last night too... currently 37 and windy
/ Need help deciding on a grapple #240
did you guys ever see this tree saw grapple it would clear alot of weed trees quick
Tractor Saw - YouTube
Interesting. However, I bet it is quite expensive and as it doesn't take the stump out there is the issue of regrowth or if the tree dies then potential potholes for horses or cattle to fall in. I can see it might be useful for someone clearing acres of small trees but think just a FEL mounted grapple would be less money and a grapple plus backhoe ripper would be more flexible with bigger trees.
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
John Deere 3010 Tractor (A66408)
John Deere 3010...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
KEEVAC SEWAGE VACUUM TANK (A65643)
KEEVAC SEWAGE...
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
