tool question.
/ tool question. #1
skytime24
clarkesville georgia
LS G3038, stihl fs90, stihl ms290, snapper riding mower, Honda gcv160, Yamaha g9 golf cart
So I'm picking up my new tractor Wednesday with loader, I know I need to check all the bolts. I'm going to Lowes today I'm pretty sure I need a torque wrench that let's you set the psi on the bolts right? What size sockets do I need for it and what other basic tractor tools do I need. I already have basic household tools.
Thanks
/ tool question. #2
I would advise waiting until you read the owner's manual to determine your torque wrench needs (in terms of ft. lbs.). You should be able to handle most tasks with 1/2" and 3/8" socket sets. You can buy additional sockets as needed if you do not already have them in your collection. Depending on the tractor, you may need a set of allen wrenches. Chances are that all of the fittings will be metric. Buy a grease gun now. Later on you will need filter wrenches if you do your own servicing.
Steve
/ tool question.
OK thank you will do, gotta go to Lowes anyways
/ tool question. #4
So, what are you getting for a tractor?
/ tool question.
I gotta get air filters for the ac unit a battery for the ole snapper and some wood puddy
/ tool question.
Just seeing if I needed to pick up any tools for my tractor
/ tool question. #8
If you have a Harbor Freight nearby, I'd suggest stopping in there and look at their tools. They are inexpensive, but quite satisfactory for somebody who doesn't make their living twisting wrenches. I've been happy with every tool I've bought from them.
/ tool question. #10
Ya might consider a fire extinguisher to mount on tractor . Not a bad idea as many here would confirm .
/ tool question. #12
Yes, box end wrenches (open and closed) are great. I would also suggest a 3/4" set of sockets eventually.
Must have grease gun!!!!
Stop by harbour freight. Yes, they are cheap tools but they are cheap. You will not use them that often and if you break one you will not cry. I have yet to break any of the wrenches or sockets I got from there but have stripped out a ratcheting socket wrench and the charger for the impact tool died.
I would also STRONGLY recommend a T-Bar style torque wrench when you get one. The spring loaded ones have a tendency to go out of spec especially if not used, weather changes, dropped, etc. The T-Bars seem to stay in spec much better and they are much cheaper! For the amount of use you will need them for, the T-Bar is a much better buy and more reliable.
/ tool question. #13
You need to determine whether you need "inch" or metric sized tools.
1963 Ford Falcon (A62613)
1963 Ford Falcon...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63688)
FRESHLY...
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
Deutz D3006 Tractor (A62613)
Deutz D3006...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
