check
Elite Member
- Joined
- Sep 26, 2008
- Messages
- 4,165
- Tractor
- 2009 Kubota BX25
![BX-TACH-N-GO-small2[1].gif BX-TACH-N-GO-small2[1].gif](https://www.tractorbynet.com/forums/data/attachments/284/284939-15236b053bef6db992f5ef5b818ed109.jpg)
I have the Kubota quick attach and pallet forks on my BX24. I haven't had them very long but I like them very much. The QA pinned on with no problem, took longer to clean the old grease off than to install the QA. I'll try to post some pics if anyone is interested.
Matt
Just bought some pin on style forks myself for a BX2200 and after 15min of switching from the Bucket to the forks, I've decided to build my own QA plate based on the design that you pin on a plate to the tractor existing FEL, and opposite it will use a hook for the center pin and instead of the side pins dropping in from the top like others used, I will use the existing pin from the side setup, just with some easier to use pins with handles. So hopefully, I can pull the pins on each side, unhook the attachment, pick the next attachment, and push in the pins from the side to lock it in. Hopefully it only holds the attachment out a few inches not to loose any lifting capacity!
More thoughts on this: If you take the bucket off an use forks, the bucket weighs about 160 lbs., and the forks? depends upon the forks. The Everything Attachments forks weigh 220 lbs., and the Kubota forks weigh in at ?
I thought I would resurrect this, because I am still contemplating whether or not to buy the Kubota quick attach for the FEL.
Has anyone done this with a BX25, and have you observed the change in lifting capacity?
Any thoughts or suggestions would be appreciated as well. Thanks
I have the Kubota QA for my BX25, broke one of the ears off the QA that holds the pin for the hydraulic ram. The welds are not good at all, little to no penetration. I have pix, will try to post tomorrow. The machine had 9.5 hours on it when it broke. Barlows sent me a new one, had the old one re-welded.
