Air Compressor
/ Air Compressor #1
DXN1EL
Texas
/ Air Compressor #2
Hi fellas
I am thinking about an air compressor for some of the "low end" size air tools like die grinders,
Shop Kobalt 1/4-in Rotary-Die Grinder at Lowes.com
I know very little about air compressors, I know the 5 gallon ones are for inflating, and I was wondering if something like this could do the job
Shop Ingersoll Rand 3-HP 60-Gallon 135-PSI Electric Air Compressor at Lowes.com
but if some one could point me in the right direction would be appreciated.
That will work but if your going to spend that kind of cash buy a 5 Hp instead.
/ Air Compressor #3
The CFM rating is what you need to be concerned with. HP, pressure and tank size don't mean a whole lot if the compressor doesn't put out the volume. I don't know if you have Eagle compressors where you're at but they have a medium/heavy duty 3 cyl. cast iron compressor that puts out 18.5 CFM at 100 PSI. I think it's an 1725/1800 RPM motor as well. Look for a cast iron head, oil filled crankcase and slower turning motor. 3400 RPM you'll be deaf in no time.
/ Air Compressor #4
Agreed, I have a 6hp 60 gln with the high speed 3400 rpm motor, She Really Hammers when she pumps. I hear it in my sleep.
/ Air Compressor #6
/ Air Compressor #7
You last two posters bought nice compressors, but for most farm and home use, those are just too expensive for many of us. When I lived out in the country, and was also in the business of repairing/rebuilding mechanics' air tools, I had the Puma PK6060V and it was actually all I ever needed. But I bought mine from a place that also built and sold their own bigger compressors. Northern Tool didn't have the Puma at that time. And then about 8 years ago, back in town, I bought this Industrial Air by Powermate Compressor from Northern Tool and now they no longer sell this one.:laughing:
/ Air Compressor #8
Hopefully that's the last compressor I ever buy! I have a small compressor for airing up tires, nail gun, etc, etc. This compressor is mostly for the plasma cutter, and CNC machine. Which I don't hardly ever use.
/ Air Compressor #9
Boy 3 grand for a Compressor is out of my League.
/ Air Compressor #10
i recomend Eaton Compressor for there value.
there built/assembled in US, they do use imported compressors on most of there cheaper models.
eatoncomressor.com
emaxcompressor.com
/ Air Compressor #13
I have a craftsman professional 27 gal. Bought back in summer really like it didn't have breaker space for a 240v compressor so it has a dual voltage motor on it 120/240v. Just takes a rewire in the motor and a new plug no big deal. It is 150psi compressor really quiet. You can talk right beside it and not have to raise voice much. Paid like $499 on sale. Wanted a 60 gal but wife said no to new panel and compressor, welder took up my last place to 240v.
/ Air Compressor #14
I just run a plain jane 6hp 60 gln. Nothing special..I think it was about $450.00. It gets the snot run out of it. 12 yrs old now.Thinking of a new one some day. I also have a 3hp 25 gln campbel hosfeld on wheels for portable option. It gets used a lot at the cabin and anything away from the shop. If you don't need portability, Go with the biggest that the budget will allow.
/ Air Compressor #16
I have a craigslist special as my shop machine. Old Quincy cast iron oil bath with few hours. Then a craftsman oil portable. Compressors have not changed much so old school in good shape is worth considering.
/ Air Compressor #17
Some compressors pull a ton of power on startup. Be sure to match wire and breaker to amp draw on start up. Mine only uses a 230v 30 amp. Some of the units on here are industrial monsters so I'm unsure what they pull on startup but I'd like to have one of those big dogs.
/ Air Compressor #18
Man, my local HomeDespot doesn't have anything CLOSE to that beast - about 5 years ago I bought a DevAir TAPV-5052, never been sorry -
Compare 3 Different 5 HP Compressors
At the time it cost me $1900, guess they've gone up a bit.
With the 5 horse Baldor, running amps is 25 - startup inrush on most compressors is roughly double the running amps, but I've not measured that so can't give you exact numbers.
Mine is on a 70 amp breaker which also feeds my welder outlets - the compressor will sometimes kick in when I'm welding, and even with the old transformer welder I've been running 5/32" 7018 when the compressor started, no problems.
Unless you plan on starting a sandblasting biz, a REAL 5 horse should be all you need - and unless you have more shop space than you will ever need, I'd look for a vertical model.
Check the link - this one meets all the (agreed upon) previously mentioned "goodies", and then some... Steve
/ Air Compressor #19
With those compressors you really must use them to pay for them. A smaller one like a good 60 gal 3 or 4 hp will do a lot as a hobby utility compressor. But if you are looking for a large compressor I would watch a 10 hp compressor on single phase as you are pushing the limits of single phase from my research. Might back off to an 8 hp or something similar. I don't see a use for that large of a compressor unless you plan on running a commercial shop or a power hammer at home.
Just my .02.
/ Air Compressor #20
Just my .02.
You might be right there. Momentary startup surge of a 10HP 240V single phase is above 200A. Circuit breakers have a built in delay so it would not blow a 60A, and the momentarty 200A would only brown you out a little on a 200A service. Normally big compressors have an unloader that prevents compression until it has spun up - so as not to burden the start. This shortens the surge period drastically.
You wont easily find single phase motors above 10HP.
larry
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A59912)
2019 INTERNATIONAL...
2019 John Deere 9470RX Tractor (A63111)
2019 John Deere...
43018CFL (A59228)
43018CFL (A59228)
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
FLEX HEADER REEL FOR 20' HEAD (A63291)
FLEX HEADER REEL...
