Parade/Hay Ride Wagon
/ Parade/Hay Ride Wagon #41
Do you know the final details of how it will be built?
By the way, I posted commercial "kicker" haywagon plans a few months back that would likely contain some info you would need.
...I posted commercial "kicker" haywagon plans a few months back ...
I am planning on slightly overbiulding:
(2) 2x8 stringers on each bolster
(5) 4x4 cross members 4-5' wide
2x6 wrapping around the crossmembers (for stakes holders and covering up cross members)
+/- 2'high guards around the perimeter of wagon with 1x 8 boards painted Farmall red
Still up in the air for decking...either 2x10 or trex decking. I kinda like the trex/composite idea as it won't shrink or allow splinters.
ALso, I was not able to find you kicker wagon post...do you have a link?
Thanks
/ Parade/Hay Ride Wagon #45
If you are going to build too small of a wagon you might want to think about downsizing the dimensions of your lumber so it is more correctly sized for the scale of the wagon you are building. Using five 4 x 4's on a very small wagon or 2" flooring would likely look disproportionate to the overall size of the wagon.
I've built a lot of wagons and more is not always better. For a small wagon with a plank floor, I'm thinking 2" is too much. And if you build only 4' wide, I'd rip the 4 x 4's smaller--or at least think about it. Maybe 3 x 4's.
If it were me, I'd scour the net as well as old advertising materials to find a look I liked and then would faithfully duplicate the wagon and it's dimensions. Worth noting here is that some IH sketches I have seen looked to be not fully to scale for the overall scene. Try to find a photo; maybe talk with some diehard IH club people. What you want is out there somewhere.
Those are things I have done in the past and they seemed to work for me.
Wish I could talk you out of the plastic flooring and back to 1" boards or 3/4" plywood. Heck, you really don't even need PT wood but I'm often in the same boat and use it anyway so I understand. The 1" (3/4") PT deck boards sold are all clears or selects with nary even a small knot so they look great. I used them on a 16 ft double axle trailer 15 years ago and they still look great and hold a 5,000 lb tractor with no trouble. Of course, they are never in the rain.
EDIT--This is a guess at the size but I'm going to say the narrowest hay wagon I could envision looking balanced to a typical wagon gear and normal tires--without downsizing the lumber and frame-- would be 6 1/2 ft wide by maybe 10 ft long. Normally I would say 7 ft wide by 12 ft long but I guess you can go smaller. You can fool with the width as long as the length is proportionate and the length looks best in 12, 14 or 16 but I suppose you could get away with 10 ft.
And what most people comment favorable about is a wagon with a flat floor with trim that extends the width of the 4x4 and leaves the stringers exposed on the ends. Then you tuck the lights into the corner of the stringers, so they don't get broken and you also have a nice flat surface for mounting the SMV. I've got pics if you want. Just my two cents, subjective opinion here.
/ Parade/Hay Ride Wagon #46
I agree. If going to 2" deck boards one could skip the 4x4s altogether. If using the 4x4s, go with 5/4 deck boards. They have worked very well for us on our full sized wagons.
Aaron Z
/ Parade/Hay Ride Wagon #47
Model 3000 - Kory Farm Equipment LLC
The above link was in you original post and if you use this frame and downsize your lumber, I believe you could achieve the aesthetic balance needed to make it look right but would caution against the small size you are thinking. I used to be an IH Cub and H guy and am pretty familiar with the materials but cannot recall that small of a wagon or with that thickness of woods. Again, just my personal opinion and whatever you choose I'll be on board with and eagerly anticipating the photos.
/ Parade/Hay Ride Wagon #48
Just a thought: If you are going to have a 2x6 "skirt" around the outside, you could just go with 2x6 or 2x8 decking and skip the 4x4s and no one will be able to see the difference. That is what I will be doing when we rebuild our 7x14 flat dump wagon next year (or this winter).
Aaron Z
/ Parade/Hay Ride Wagon #49
Here's one a friend of mine built from scrap minus the running gear which which he restored.
/ Parade/Hay Ride Wagon #50
Looks like a Ford Model T frame.
Bruce
/ Parade/Hay Ride Wagon #51
Yup, sure looks like a T frame. Cute little wagon.
Any idea of the dimensions?
/ Parade/Hay Ride Wagon #52
Another argument for PT 5/4x6 decking is the rounded edges.....
Dean
/ Parade/Hay Ride Wagon #53
I believe it is 6 by 12. And he retired from Ford as a Millwright, so I would bet he would lean toward a Ford chassis. He didn't say specifically where he got it but mentioned getting some things from the junk yard.
1996 TIMPTE ALUMINUM 96" X 45' HOPPER BOTTOM TRAIL (A63290)
1996 TIMPTE...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
INDUSTRIAS AMERICA 12' HYD LAND LEVELER (A63290)
INDUSTRIAS AMERICA...
Attention (A57148)
Attention (A57148)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
