Quick hitch other than Harbor Freight?
/ Quick hitch other than Harbor Freight? #71
Wouldn't it be more advantageous to just change the lower pins with reduced thread class 2 pins, I think I saw them at TSC.
I cannot be sure about all QH's but, on most I think the lower arm hooks are CAT 3 so, on a CAT 1 QH your are bushing from CAT 1 to CAT 3 and on a CAT 2 QH you are bushing from CAT 2 to CAT 3.
/ Quick hitch other than Harbor Freight? #72
the one piece adaptors get you there without doubleing up and they have a stop collar built into them. using bushings 1 to 2 and 2 to 3 with a lock pin will also get you there. Price wise changing the pins is counter productive your better off getting the adaptors.
On a related topic why in the h@@L does a cat one quick hitch come with oversized hooks in the first place.:confused:
/ Quick hitch other than Harbor Freight? #73
I am not certain that one piece bushings are necessary on all implements. I know they aren't on implements with a clevis style hook up. I keep all my QH compatible implements with bushings on them.
It makes no sense to me why a Cat1 QH uses CAT 3 hooks. Maybe the original inventor wanted to sell bushings with every QH. Someone should make a weld in reducer for the QH hooks to make them CAT 1.
/ Quick hitch other than Harbor Freight? #74
And mass produce them and sell here on tbn!
/ Quick hitch other than Harbor Freight? #75
/ Quick hitch other than Harbor Freight? #76
I have Cat 1 & Cat 2 lower pins, all with the same thread size for mounting, so maybe my implements don't know or care whether they will be used with a Cat 1 or Cat 2 3PH.
Am I so wrong to think that QHs are designed for ease of use rather than to save us buying extra parts to make 'one size fit all'? :eek: (I thought that was for spandex apparel. You learn something every day, eh?)
/ Quick hitch other than Harbor Freight? #77
These "bushing sets"...
http://www.northerntool.com/shop/tools/product_200479426_200479426
...assuming it includes two bushings and two pins -- but assuming these things always gets me into trouble. Doesn't exactly say what is included. do I need to buy one or two for each implement?
Also, who is the best supplier for top link adapter for non-quick hitch compatible implements?
/ Quick hitch other than Harbor Freight? #78
NorTrac Quick-Hitch Bushing Set Fits Category 1 Hitches | 3-Point Hitch Adapters| Northern Tool + Equipment
1 kit per implement. top link adapter for non-quick hitch compatible?? Whats that.
/ Quick hitch other than Harbor Freight? #79
A few attachments have top links that are not approachable from below.
/ Quick hitch other than Harbor Freight? #80
I think you could back in with the toplink shortend and latch the lift arms and extend the top link then put the toplink pin in.
Towable Trash Pump (A59228)
Towable Trash Pump...
2017 Ford F-550 Mason Dump Truck w/ Liftgate (A59230)
2017 Ford F-550...
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
