flusher
Super Member
- Joined
- Jun 4, 2005
- Messages
- 7,572
- Location
- Sacramento
- Tractor
- Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
I use a Hobart Stickmate LX AC/DC stick welder around my 10-acre place. About $400 at Tractor Supply. Needs 220V wall power. I'd advise against 110V units--usually have duty cycle limitations. I've never had my welder kick off when pushing it to higher duty cycle.
Start honing your welding skills with the easy rods (6013, 7014, 7024 in 1/8" size). Then when you get the hang of it start using 6011, 7018, which take a little more practice to use effectively. 6011 is a high arc force/deep penetration rod that used for initial root passes and can be used on dirty, rusted material. Use one of the other rods for capping the root passes.
Get yourself a decent auto-darkening helmet. Mine is a $50 unit from Northern Tool. Never been flashed while wearing that helmet.
Good luck and be careful out there.
