Which type of welder would be best for my needs?
/ Which type of welder would be best for my needs? #21
I use a Hobart Stickmate LX AC/DC stick welder around my 10-acre place. About $400 at Tractor Supply. Needs 220V wall power. I'd advise against 110V units--usually have duty cycle limitations. I've never had my welder kick off when pushing it to higher duty cycle.
Start honing your welding skills with the easy rods (6013, 7014, 7024 in 1/8" size). Then when you get the hang of it start using 6011, 7018, which take a little more practice to use effectively. 6011 is a high arc force/deep penetration rod that used for initial root passes and can be used on dirty, rusted material. Use one of the other rods for capping the root passes.
Get yourself a decent auto-darkening helmet. Mine is a $50 unit from Northern Tool. Never been flashed while wearing that helmet.
Good luck and be careful out there.
One other thing, if you do not have a torch, I recomend it first.
It can cover most jobs, and is by far the most versitile tool since the hammer.
Cutting, brazing, soldering, bending, heat shrinking, removing stuck nuts, welding, gouging, weld removal, fixing cast iron ect
With a bit of practice, they can do some very nice welding too.
What other tool can go from cutting foot thick steel, to brazing very thin sheet metal, to welding 1/4" steel, with just the change of a tip?
I do have a small torch with the peanut bottles, but am certainly no proficient with it.
That is a beautiful tractor in your avatar.
Thanks for the advice, especially about the rods. I have been searching for this exact information.
/ Which type of welder would be best for my needs? #24
Thanks, I wish it was mine.... LOL
The closest thing I have is the old cockshutt/oliver my dad and I are going to restore for a winter project.
My dad grew up with one of those john deere 830s on the half section barley farm. They were responsible for quite a few tankers full of labatts beer over the years.... LOL
Just checked on stock on PA 200. New PA 200ST's will be here in 10-12 days. This will be an improved model with stick/tig function. Supposed to have greater arc force control, hot start etc. However, it will be rated at a lesser duty cycle of 35%. Not bad, but not like the old ones. BUT with that said, these units have had a lot more rigorous testing than previous models. Unit weight and design has been streamlined. Still will be 6010 capable and though I haven't tried one, I've been told it is better than the older units with 6010.
Because of the posters here, I have narrowed down my options to Everlast and Longevity, most likely in the 160 amp. - 200 amp. range. I like the idea of a TIG option with foot pedal, hot start, arc force control, etc., along with dual voltage if possible for the times when high amperage is not required and 110VAC may be handy. All of these items sound like they would make it easier for a newbie to learn and do a better welding job. Or maybe not. And realistically I think that 160 amps is all I would ever need. But what do I know at this point :)
/ Which type of welder would be best for my needs? #26
That is a really nice avatar/picture or whatever it is called in you signature box. Pretty cool.
That guy is not worth a **** as a weldor, you know how many years he's been trying to start that one rod? :laughing:;)
At this point, the Everlast PowerArc 160 STH looks like the best bang for my buck, but I have not made a purchasing decision.
/ Which type of welder would be best for my needs? #29
/ Which type of welder would be best for my needs? #30
If you are considering hardfacing implements or edges of components you might consider at least 200A in a stick welder. At least that has been my experience.
2001 CATERPILLAR 140H VHP MOTORGRADER (A59823)
2001 CATERPILLAR...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
Giyi GY-QSJ Mini QA Broom Sweeper (A60463)
Giyi GY-QSJ Mini...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
