Digging with FEL
/ Digging with FEL #21
Kenny, what would be better? I'm a newbie FEL owner and I would do every one of these scraper options/mistakes if only to see what seemed to work better.
Now I'm operating at lower rpm, not throwing the full weight and power of the tractor into it.
I've leveled some heavy gravel backing up slowly and nothing seemed too unhappy. When do you know you are crossing the line, short of getting hit in the eye with hot
hydraulic fluid?
Personally I always go in slow, testing how things react and then try to use the least power and capacity of the tractor that will get the job done. I need to do this because I am still relatively new to my machine. I know what I don't know and it's a lot. So... what do you suggest for "back blading" with a FEL?
don't mean to hijack a digging issue for a blading issue but I think we all want to know not only how to get the job done but how not to damage our expensive machinery.
I don't know if your would bend the loader arms but if you curled the bucket so as to lift the front end of the tractor off the ground while back dragging the bucket you would put a lot of pressure on the bucket lip and frame attachment points on the loader...
I have used my bucket back dragging with the tooth bar but did not use that much down force...
/ Digging with FEL #22
I dig quite a bit (mainly ditches) with my JD 2520 & haven't had any issues & my soil is heavy clay. Standard bucket but don't really need to level what I am working on.
/ Digging with FEL #23
I think we all have to remember that these are front end loaders, not bulldozers or rear ground engaging rippers of sorts.
I bought my Kubota with an expensive and super heavy duty bucket Long grapple which has worked wonderfully in the woods and in my
firewood operation. And it has what seem to be four inch teeth on the front, with a tooth bar option I asked for.
I also just bought a standard basic Kubota bucket for the front, to increase my lifting capacity and do a better job in soft stuff. That has a standard
plain front. And it's pretty useless digging into things compared to the heavier toothed bucket. But if you want to leave things smooth in landscaping, those
teeth create their own issues. Which is why, and it took me a while to realize this, having two buckets is really nice, each optimized for certain tasks. And buckets are easy
on and off.
I'd use a box blade to loosen things up. They're fun to use and can bite in enough to stop the tractor, but if you don't have one,
and want to do this all with a bucket, well, any chance any local dealers would have a used box blade you could rent for a day or two?
and a box blade usually has a purpose built rear scraper so you can use it in both directions. More importantly, it's designed to do this, while your
FEL, even used with a soft touch, isn't.
I bet if we all had a 100hp TLB, like a Case or JD, this worry about bending the equipment would be silly.
I watch the excavator working near where my garden is, and it pushes stuff around like child's play effortlessly. Great fun to watch.
The suggestion of having weight on back is really good I think, providing a more stable hopefully balanced platform.
sorry for overthinking this, but I've had the same concerns as the OP.
/ Digging with FEL #24
That technique is a fantastic way to bend the curl cylinder rods on the FEL or blow hoses.
+1 to that. Kind of like digging by scraping your shovel across the ground instead of digging with it. Just as that's hard on your arms and back when you're doing it, it's also hard on the tractor because neither shovel nor FEL are designed to work that way. Leveling loose ground that way is fine.
The lip of the bucket will cut like a shovel when used properly. With little equipment like this, you don't have a lot of weight to work with, so hard ground is tough. A toothbar helps a lot but the scarifiers on a box blade are specifically designed to dig into hard surfaces. We've dug and moved a lot of dirt with our BX, using the FEL+toothbar on the front and a 48" box blade in back. Once the soil is loose, you can fill the bucket and then the box blade on the same pass.
As between a backhoe and a boxblade, it depends on the situation. If you're regrading a dirt road, where digging in only a couple of inches is needed, the boxblade is the obvious preference. If you're removing 18" of soil from an area, either would work, probably a backhoe would be best. I'll be removing a mound of about 50' x 30'x 2' later this summer. Will start by opening it up with the backhoe since it's hard-packed, then switch to the FEL and boxblade.
/ Digging with FEL #25
Machines like Bobcats, and tractor loaders were designed to be loaders, Ag tractors with FEL attachments are really just material handlers. I do dig with mine. It can be done, but as the man said they not bulldozers. Most manuals I have read suggest no more than 30-40deg. when backdragging so you won't bend the curl cylinders.
If I needed to do lots of digging and moving of rocks, I would suggest renting a piece of construction equipment. (Bobcat, or TLB, ect.) When the heavy stuff is done, get your tractor to maintain the property.
:2cents: Bill
/ Digging with FEL #26
I agree with Kenny on this one.. the trouble with back dragging with the bucket in the dumped position is that it gives the bucket tremendous leverage over the lift cylinders.
Roll the bucket down and have a look at the geometry of the loader. The whole length of the bucket acts as a lever around the bucket pins, trying to compress the curl cylinders as you drive backwards. Since there is no pressure relief on the work ports of the loader valve, if the bucket lip hooks something solid, pressure increases in the cylinders and hoses until something either bursts or bends, or you run out of power or traction. Usually the curl cylinders will bend first on a smaller loader, next hoses will burst...
If you want to back drag material, and it IS a valid way to use the loader, be absolutely sure that the lip of the bucket can't get hooked on something solid.
I try to keep no more than a 45 degree angle between the ground and the bottom of the bucket when back dragging, and the most effective way I've found to back drag is with the bucket bottom nearly flat on the ground and a slight downward pressure on the loader. It's more for smoothing material than anything. It will wear the bottom of the bucket fairly quickly if you're in rocky ground or on concrete or asphalt, however.
An FEL really isn't meant for digging.. the contact area is too wide to be effective. That's why a hoe is better, concentrated pressure on a much smaller bucket lip. They're intended for loose materials, although they will dig to a certain degree. Skinning sod off the ground should be fine, but it won't be pretty.. it's hard to keep the bucket even close to level, especially after you get a few wheel ruts made.
Sounds like you have a pretty good dealer if he pointed that out.. although I'm sure he'd like to sell you a back hoe too :)
Sean
/ Digging with FEL #27
...but I think we all want to know not only how to get the job done but how not to damage our expensive machinery.
Have you looked in your owners manual for the loader? Mine has lots of guidelines on proper operating procedures, even has pictures so you don't have to read too much. For backdragging it says to fill the bucket, place bucket flat on the ground, put it in float position, and back up. This forces the heel of the bucket to do the grading.
Manual doesn't say this, but I grade going forward by rolling the loaded bucket all the way back, put in float, and then going slowly forward, which uses the bottom rear surface of the bucket to grade with. If you lose traction, raise bucket a little then hit the float again.
I agree with other posters, never backdrag with bucket rolled forward. I would not even do that for loose material, just too easy to put huge stresses on cylinders and components. Ditto for grading going forward with bucket rolled all the way forward, same problem.
/ Digging with FEL #28
Hey VT,
That's a nice solid-looking BB and of course, it is a well known brand name. The condition it's in also looks pretty good, and it is a good width for a BX. Do you know how much it weighs? If not ask your dealer, because the heavier, the better, but then again, with a well-built unit like that one, you can add weight as needed. Around here, that BB for that price would be an excellent deal!
With ours we often add 100# or more, even though it is already pretty heavy, just to enhance it's ability to dig in.
Now that we have our #600+ ballast box completed (branded as Kubota and bought from our K dealer, but with a slightly different paint tint than the tractors, and with an additional name plate from a Canadian mfg), we don't leave our BB on all the time, but prior to that, the BB never came off because it worked so well counter-balancing loads we picked up with the loader and also helped tons with traction.
We needed to do some excavation of our pond banks last year, along with some stump pulling, so we rented a trackhoe or mini-excavator for a weekend, and despite my complete lack of any prior experience with one, it went very well. So if you have an occasional need for extensive digging, that would be a great rental to try.
Just my :2cents: again,
Thomas
/ Digging with FEL #29
I'm not encouraging anyone to tilt the bucket on edge and back drag. I'm NOT saying to do that. For sure I'm NOT saying to tilt it back past straight edge and I'm NOT even saying to tilt it not quite straight up edge and back drag. NOT is what I'm saying. I am saying that I've been doing it that way for years with several Kubotas and never broke, damaged, bent anything. Never thought anything about it until I started reading here about how it will destroy my tractor and now when I do it I always look for the bucket to crumble, fall off, turn side ways and blow up my motor. I will concede I do it less often with the bucket pulled back further than straight up because when it hits rocks in that position and doesn't make them pop out of the ground the bucket makes this PING sound as the rock/bucket separate. WARNING do not do what I've been doing for years with my Kubotas with FELs.:eek: Again, DO NOT do it the way I've always done it because you could damage your tractor that you bought to do those hard jobs to save your back. If you damage it then your going to have an expense to get your working tractor fixed!:eek: Course I didn't think my tractor was going to turn over on its side when it did, thought maybe it would on some other times but NOT the time that it did. I am NOT a good example of how to use a tractor.
/ Digging with FEL
It weighs 250 lbs. I think it's a bit lighter than other 48" BBs I've looked at. But the price is right. They will even deliver it for the $350. Not a bad deal.
/ Digging with FEL #31
Perhaps the Mitsubishi's are tougher than other brands as I use a tooth bar and back drag aggressively as well as excavate much like a shovel would and over 10 yrs or so have not damaged anything other than a scored cylinder rod (due to gauge on shaft from dynamited stone that got wedged) and a loose bolt that elongated an attachment hole.
My rears are weighted plus I have 300# counter weight and often have had the rear up in the air.
The one thing I never do is to smash bang the bucket into things. I let the hydraulics do the work and ease into stuff.
When loading I always curl as I lift, when rolling a big rock I place the bucket heel on ground and curl with the lip.
Hydraulic cylinders are very much like shock absorbers (same principal) and prevent lots of damage.
OK, I have only 1300 hrs on my tractor but everything is still tight and no bushing noticeable slop.(I do grease @ regular 8-10 hr intervals)
A tractor is a tool, to be used but not abused. INMHO, smash bang is the worst abuse smooth easy movements is the way to go.
/ Digging with FEL #32
Look in the Operator's Manual for your tractor. There will be a page: IMPLEMENT LIMITATIONS, or something like that.
Get a box blade near to maximum recommended for your tractor. There is NO hydraulic DOWN PRESSURE on the 3-Pt. hitch. The weight of ground contact implements is the single most important factor in how well they cut. Sometimes we have to compromise when buying used but if you buy too light a box blade it will not cut the way you expect.
/ Digging with FEL #33
I think you can use a FEL just fine for digging. We have an above ground pool, and while it may sound strange, I had to dig out about 3 feet of dirt on one side to level it out. I used the FEL on my BX2350 to do this. Like someone else said, it does tend to dig in and gouge, but with some practice, it can be done. As far as back dragging, unless the soil is really loose, this won't dig down at all, but it does work well for leveling out the ground if you have a little loose dirt.
/ Digging with FEL #34
:drink: :thumbsup:
/ Digging with FEL #35
I am surprised at the comments here, you CAN dig with FEL. One thing I would like to stress though - you dont do digging with backdrag motion. KennyV is right , you are liable to break or blow a line/seals. You can dig, but you are not doing it like you would a hand shovel. You just tilt the bucket downwards enough to start digging and then start scooping lifting and tilting bucket up. Go slow and easy and it will get done. The amount you can scrape out by pushing into the ground going forward all depends on soil conditions.
/ Digging with FEL #37
I have a slightly larger machine (B2620) with a backhoe and for what I was doing the bucket was WAY faster than using the backhoe.
It was a septic field install. Of course I used the backhoe to dig the hole for the tank but for the field I dug a 2000 square foot hole 12" deep with the bucket.
Once I had the leading edge of the field dug I simply used the bucket in a vertical position to shave off the edge then tilted bucket horizontal and scoped up the cutting.
In total I have moved 320 yards of material (almost 2,000 bucket loads!!) Would have loved a bigger machine but "I danced with what I brought" as the old saving goes and the B2620 different let me down 1 bit!!!
So this little machines are definitely slower than the full size machine BUT still very capable and a lot of fun as long as you are not in a rush.
sorry for upside down pics but have no clue on how to flip.
/ Digging with FEL #38
Geeze, boakley, is that your Summer place in Antarctica?
/ Digging with FEL #39
My dealer talked me out of a backhoe and I am very glad he did, because for less than that money, we got a boxblade, toothbar, a combo spade (though that is the implement I like least, it does have uses)
Thomas,
Could you tell me some of the things you don't like about the combo spade. I was about to order the pallet forks only version.
Stuck
/ Digging with FEL #40
The soil and how wet it it is makes a big difference in digging with a FEL. Mine is mostly clay. I have spots where it works and ones that don't. I give it a try and if it takes too much power I use something else or bust it up with the box blade points. Still learning.
I have a piranha toolbar on a BX2200.
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
INOP/NON-RUNNING 2005 Freightliner M2 106 Day Cab Truck, VIN # 1FUBCXDL85HN88678 (A61165)
INOP/NON-RUNNING...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL8DL188002 (A61165)
INOP/NON-RUNNING...
2016 KENWORTH T880 TRI-AXLE DUMP TRUCK (A62130)
2016 KENWORTH T880...
(INOP) TOWABLE MANURE PUMP (A62131)
(INOP) TOWABLE...
