Can I use a Cat 2 quick hitch on my cat 1 tractor, but with mostly cat 2 implements?
   / Can I use a Cat 2 quick hitch on my cat 1 tractor, but with mostly cat 2 implements?
Well, I heard back from the Landpride guy, so far so good.
Yes, [for the HRL3578] you can use category 1 or 2, it has a stepped pin. And it's an 04 model.
:thumbsup:
   / Can I use a Cat 2 quick hitch on my cat 1 tractor, but with mostly cat 2 implements? #12
I bought a HFT QH only to find it won't fit most of my attachments (maybe 1 or 2) without clear access to get the 'hook' under the top link pin on 'em. (ASAE standardization helpful) .... Off I go to order Pat's easy change 'cuz I'm drawn to its flexibility without committing to any confinement with the top link variations.
All but one of my tools have Cat-1 pins & my new (last month) tractor will handle all but one that has a fixed bar vs pins for the lift arms. I have a handful of bushings to slip on the smaller pins if I choose the Cat-1 to Cat-2 PEC setup, or could put Cat-2 pins on the others. I'm pondering whether I ought to just 'off' that 3-bottom plow with barely 30hp on the drawbar. (pure sand here, so a disc will do for most after some sub-soiler work.)
btw: My new iron (HST) has a seat safety switch and I stayed away from the recent conversation about whether to bypass such a thing. After learning to play 'Simon says' with range selector & brake lock it'll stay & I'll be ok with the lawyer-proof system & my butt covered against the worst possible scenario. (I can no longer nudge the HST pedal while standing alongside to line pins up to lift arms.)
Anyway, it was here that I got the tip about TSC's $25 top links, and my local store has 'em aplenty. So much for big variations if I can buy a few extra for certain attachments, with lengths & color codes for each vs constant huge adjustments. I'm ok with climbing down off the seat if I can muscle the s__ on & off at all. (PTO shaft, too)
My bottom line is that A QH is better than none. It's just a matter of considering all the options before I $pring for a few extra pieces. So, tell me to broom the ponderous plow & I'll be happy with Pat's Cat-1 setup, OK? :)
I I'm pondering whether I ought to just 'off' that 3-bottom plow with barely 30hp on the drawbar. (pure sand here, so a disc will do for most after some sub-soiler work.)
I'd love a plow like that!
   / Can I use a Cat 2 quick hitch on my cat 1 tractor, but with mostly cat 2 implements? #14
Me too. Hard to find 3 or 4 bottom mounted plows around here without paying an arm and a leg.
   / Can I use a Cat 2 quick hitch on my cat 1 tractor, but with mostly cat 2 implements? #15
I bought a massy 3 bottom Thursday of last week its a model 82 I payed 650 for it
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2012 Peterbilt 389 Semi (A59814)
2012 Peterbilt 389...
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
John Deere 5055E (A53317)
John Deere 5055E...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
