Right model for 30% grade hill
/ Right model for 30% grade hill #21
That is a nice chart. If you could print it on a something clear you could look right through it to determine the grade/ angle. Now I wonder if there is a App for that?
Just print it on a clear plastic sheet. The white won't print.
Bruce
/ Right model for 30% grade hill #23
Like a sheet protector?
That might work. Be careful, as it will take longer for the ink to dry. It won't soak in.
The sheets I've seen made for printing on have a very slight satin finish.
Bruce
/ Right model for 30% grade hill #24
For the iPhone. Yes. I carpenter :). Works pretty well.
Sent from my iPhone using TractorByNet
/ Right model for 30% grade hill #25
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=319800"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=319801"/>
I have similar apps on my android stuff. I have acutally used them in a pinch. I was thinking it would be nice if you could hold the phone up, camera be on with a overlay of the chart BCP posted. The phone could tell you when you were holding it level like the level apps do. I really got this thread off track.
/ Right model for 30% grade hill #26
the App for stability with that kind of a grade would be a Ventrac (or Steiner)... probably a smaller unit would be suitable for the area that you are covering. I understand the % and degrees issue, but really can't visualize the property. I believe that it kinda depends if you are going up & down or across and back.
Ventrac's - I like them :)
/ Right model for 30% grade hill #27
How much does the Ventrac app cost?:) It would seem to me that a 30% grade ain't that steep, and most anything will handle that. Especially if we are just talking mowing, and not carting round bales around with a loader.
/ Right model for 30% grade hill #28
A Kubota BX will handle 30* easily up and down. 30* about the limit for it going across.
Read your owners book, you won't get enough oil feed.
/ Right model for 30% grade hill #31
There is one.. dunno why its off in that video..
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
